Query re WA registration
jaymac
Post by jaymac »
I have just joined the forum as I have my eye on an unregistered EK. After searching lots of threads ( awesome info and great pics) and the WA Licensing dept guidelines, I'm still not sure about whether the standard conversion to a red 202 and a Hr front end and disc brakes can now be approved. Wondering if any one has had recent WA expereince in registering an EK with these modifications, as I am better off knowing now rather than after i have the car.
Re: Query re WA registration
G'day Jaymac , welcome to the forum mate :thumbsup: A red motor conversion is fairly straightforward to licence , has it been licenced with a red before ?
You will need an engineer to sign off on the conversion ,, where are you located ? North or south ?
jaymac
Post by jaymac »
Thanks Blacky
I am south of river and no it was not licensed with the red before, its been out of action for quite a while.
i am wondering if the engineer says its OK and then when I put the modification application in, it gets knocked back or i have to add collapsable steering and dual brake system??
does the demister have to work??
the plan is to fit power steering and the KB laser has been recommended to me, but I haven't seen any mention of it on the forum.
hope it doesn't take too long to get approval!
You will more than likely need collapsable column, 2 speed wipers , demister and a brake upgrade.
Pick someone close to you and run it by them - Salvatore Rossi is pretty good to deal with , as are Dan Pitic and Jack Apgar but they might be a bit far away .....
Romeo Hillerin - Romarta Consulting - 12 Kearney Mews, Marangaroo - 9343 7589 - romeoh@bigpond.net.au
Jack Apgar - WJ Apgar - 11 Telopia Dr, Duncraig - 9246 1600 - apgar@iinet.net.au
Neil Butler - NB Drafting - 17 Jolliffe St, Busselton - 9975 14561 - nbdrafting@primus.com.au
Graham Dyke - WDF Services - 35 Robinson Rd Wandi - 9397 0124 wdf@upnaway.com.au
Jim Hope - 22 Bonnyrigg Pass Kinross - 9305 5752
Max Kurtze - Vehtech - 20 Exchange rd Malaga - 9249 1224 - admin@jshop.com.au
Fred Mackay - Braking Analytical Services - 50 Broadway Embleton - 9249 5401 - baswa@iexpress.net.au
Dan Pitic - Endracon - 6 Brighton Mews Hillaries, 9307 1436 apitic@bigpond.net.au
rodney Style - Rodney Style & Ass - 6 Belinda Cl, Cloverdale - 9277 5050 rostyle@iinet.net.au
Andre Syed - 200 Bryke St Attadale - 9330 4205
Tito Trivedi - Trivedi Design - 8 Levey Rs Winthrop - 9332 2030 - tito@trivedi.com.au
Bret Silich - 5 Johanson Prm, Murchoch - Brett.silich@iinet.net.au
Terry Southam - Terry Southam & Ass - PO Box 1608 Booragoon - 9310 2030 tsoutham@bigpond.net.au
Jay daviot - GTSA Eng - PO Box 270 Maddington - jdaviot@gtsa.biz
DJ Abbott - Automotive Investigation - 6 Viewpoint Cove, Ballajura - 9428 9109
Don Stevens DE Stevens - 183 Bateman Rd Brentwood - 9364 9557
David Stewart - Stewart Strategic and Operational Services - 202 Hampton Rd Nedlands - 9386 6466 - david@steward.allogic.com.au
Salvatore Rossi - Rossi Mechanical Eng - 82 Basildon Rd, Lesmurdie - 9291 9368 - svrossi@iprimus.com.au
bat53retro
Post by bat53retro »
g'day all
youwill need collapseable column elec wipers demister seat belts washers . but if you fit a 149 you don't have to . about the power steering give me a call
cheers bat
jaymac
Post by jaymac »
thanks for the advice, I contacted Dan, he was a great help. I decided not to get this one as there were a couple of complications,still on the lookout for an FB or EK, and now know what i am in for!
