Floor shifter for grey
FB1960
Post by FB1960 »
Help
looking for photos and measurements of the single shaft style of floor shifter for a standard grey crash box
I have the linkage parts but not the angle iron base and shaft
this is the type that bolts to the bottom of the gear box
any help is greatly appreciated
picture below is type I'm looking for
Marty
Going nowhere, getting there fast
southcoastkustom
Post by southcoastkustom »
I have one Im taking out of a car in the next couple of weeks. I'll let you know when and if you want it, let me know. :)
not too shiny thankyou.
FB1960
Post by FB1960 »
Interested in shifter
sent you a P.M.
Marty
Marty
FB1960
Post by FB1960 »
Still looking for a grey motor gearbox shifter
any help appreciated
Marty
Gday Marty
I bought one brand new only 4yrs ago.
They may still make them.
Contact SPECO THOMAS SALES
Ph (03) 555 7244
Fax (03) 553 2841
Speco Speed Shifter Part# 61 1470
If they stopped making them,
See if they can chase up any unsold stock
Cheers Jeff
yeprat1
Post by yeprat1 »
speco no longer make these shifters unfotunately
FB1960
Post by FB1960 »
Tried speco myself
I keep looking on ebay too
No luck there
Marty
Gday Marty
I do have the parts your looking for,
But I dont want to part with them.
I can give you all the measurements you'll need.
When I bought my shifter,
I remade most of the parts.
The angle iron mount is just no good,
You cant do it up tight,
because it fits onto the gearbox inspection cover,
which has a cork gasket that you dont want to crush.
When I made mine, I made an inspection cover
from 6mm steel plate, & welded my own angle iron mount to it.
I will take photos & give you all the dimensions as soon as I can.
Cheers Jeff
Gday Marty
I have some pics & drawings for you, I hope it helps.
This is an old home made shifter by the looks,
I bought this before I found out I could still buy one new at the time.
This pic shows the layout of an assembled shifter.
This is the shifter in my car showing the 6mm plate inspection cover,
With the angle bracket welded to it, and bolted on as one piece.
This is so much stronger, much more reliable & solid feeling to use.
Also posted below, is the fitting instructions for the speco shifter.
If you have any questions, dont hesitate to ask
Cheers Jeff
FB1960
Post by FB1960 »
Thankyou so much for the time and effort you have taken to help me out
it is greatly appreciated
I can now make one myself
Does it take much slop out of the gear shift itself as opposed to the column
This shows what a great forum this is
Marty
Marty
FB1960 wrote: Does it take much slop out of the gear shift itself as opposed to the column
Gday Marty
The column shift is sloppy because it worn out in all the linkages, which can be repaired.
With the floor shift any slop is taken out by how tight the bolts are tensioned.
This will take trial n' error to get it between sloppy, & stickey.
The first stick I made, was just a piece of 5/8 rod, that I used to
test different shapes & lenghts to make sure it cleared the seat & dash.
Once your happy with that, use it as a templete to make your good one.
One thing I found with mine, was the best shape turned out to be
dead straight. I found any swan neck design wanted to twist as you go
from 1st to 2nd across the 'H' pattern, making it stiff.
The straight stick works a treat, but it is close to your left leg.
Im glad to be of help to you,
because I appreciated the help
I've recieved from others.
Cheers Jeff
fb cruzn
Post by fb cruzn »
i had to go searching for this thread, i am gonna have a go at making one :?
why dont we make it sticky?
i read it years ago and hoped it still had all the pics.
good work thommo
Done :D
FB1960
Post by FB1960 »
In case anyone is looking for these there are new ones popping up on eBay at the moment
Look under floor shifter or Holden EK
starting bid at $75 and $15 postage
Marty
FB MAD
Post by FB MAD »
They are limited in supply though as Speco haven't made them for a few years now and the seller you refer to is selling off old stock ( info gained from a phone call to Speco and the ebay seller ).
