Tasmans Welding.
Tasmans Welding.
Is there anyone thats changed stud patterns on old alloy wheels by way of welding and redrilling the holes.Iknow the effort,but i luv the old skool look and found a nice set of14'' tasmans,Thanks, Gaz.
Re: Tasmans Welding.
probly easier and safer to change the stud patter on the car to suit the wheels
what stud pattern are they ? early valliant are very close to early holden so you may be able to modify the holes
Yeah they're early val,no problem with the welding,it's get;n the holes drilled accurate,maybe a w/shop that redose axles etc,thanks. Gaz,harry186 wrote:probly easier and safer to change the stud patter on the car to suit the wheels
- BILLY BLACKARROW
- State: NSW
Where are you there is a place in Newcastle PROMAC that does wheel repairs they may be able to help don't know their No off hand
BILLY
BILLY
BILLY BLACKARROW
Thanks Billy i'm in Melb,i'll weld the holes up and wait till i get an answer here and go from there.Cheers, GAZ.
look for a wheel place try maikiki on here he had some chromies made up so knows the name of a place
Thanks for the advice guys,but i've rang all the bigwigs who do the mod's but they don't wanna know.When i get to the Nats ihave a few friends who could [maybe ]set me straight.
I've only been on the forum a short time,never met anyof you but i ask for help and i get it.This really is the Aussie way,thanks again guys and hope you all have a safe XMAS! Gaz.
what natsFINK EK wrote:When i get to the Nats ihave a few friends who could [maybe ]set me straight.
what about drilling yorself
bootlegger
I can't imagine its that hard to drill them. Make a template out of cardboard and then steel. Make sure its accurate and it lines up with the centre hole so you know it centred. Clamp the template on.
Then drill it through.
Anyone with a half decent mill can drill a rim - I did a set of 15 x 10 Hotwires a few years back and its not that hard , the problem these days is public liability etc.
I know what your say'n,believe me i've tried sourcing one,if all else fails i'll use a pedestal drill, but inthis game i've learnt to be patient .Blacky wrote:Anyone with a half decent mill can drill a rim - I did a set of 15 x 10 Hotwires a few years back and its not that hard , the problem these days is public liability etc.
where are u from fink?
Mark it out on steel first,forget about the cardboard.bootlegger wrote:I can't imagine its that hard to drill them. Make a template out of cardboard and then steel. Make sure its accurate and it lines up with the centre hole so you know it centred. Clamp the template on.
Its an extra step that can only increase any error in marking out.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Hey Browno i'm in melbs western suburbs.wot179 wrote:Mark it out on steel first,forget about the cardboard.bootlegger wrote:I can't imagine its that hard to drill them. Make a template out of cardboard and then steel. Make sure its accurate and it lines up with the centre hole so you know it centred. Clamp the template on.
Wot 179,i was thinkn use'n an old brake drum,cut the guts out with the oxy ,that should be accurate enough,true.
