Around the tail light they was a grey (silastic) of some type. It looked original.
About to put the tail lights back in and wondering what everyone was using to seal between the light and the body?
What to use to reseal tail lights
ingredient in beer
ingredient in beer
Re: What to use to reseal tail lights
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
ekwags62
There is a product used in kitchens for sealing hotplates and sinks to the benchtop that comes in a roll with non stick paper between. Dont know what its called but you might be able to get it from an appliance spare parts store, maybe Bunnnings or plumbing supplier. Lot more user friendly than using messy silicones and is a similar consistancy to the original. Then again you could buy shares in Blu-tac.
Mick.
Mick.
EKSPCL
Glazing tape would do the same trick.
It's used between the glass and the window instead of silicone.
Mask up the car and mask up the tail light,piece of cake.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
ekwags62
Yeh thats it same stuff. Certainly lot less mess. No matter how hard you try silicone has a mind of its own. Also makes it easier to remove light if need be without damaging the paint. Silicone sticks like sh.. to a blanket and you'll never remove the light without damage to the paint.EKSPCL wrote:Glazing tape would do the same trick.
This post is just to make sure that you are aware the link I put up is not for silicon.
It is for Mastic,a product manufactured for this application.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
I would (have) use the mastic over tape.
