Can anyone tell me if you can still get EK rear slave cylinder kits over the counter??
Just adjusted my rear brakes this arvo and found the passenger side rear weeping fluid..DAMN IT!..and I wanna fix it before the Nat's...as you would do.
Scotty.
Woofto Car Club Member No 2
if you find out the size of the rubber cups that's all you'll usually need and you can get them in oversize, or you could lst time i bought some which was a few years ago now plus i had a good spares place
harry186 wrote:if you find out the size of the rubber cups that's all you'll usually need and you can get them in oversize, or you could lst time i bought some which was a few years ago now plus i had a good spares place
Thanks Mick...my spares shop 'aint too bad for getting bits I need. I'll look into it tomorrow.
Scotty.
GOT 'em.
I picked up a set today for the princely sum of $9.60.
Seems the weeping has stopped since I've adjusted the brakes (WHEW!) although I thought it would since it was pumping out so far and is'nt now. I'll take 'em with me to Sawtell (& further) ,,,just in case.
Scotty.
