Trimatic help
minifb
Trimatic help
Post by minifb »
Ive got a trimatic in the pig and ive replaced the clip that holds the speepo drive thingy on the shaft at the back of the gearbox three times now.(yes im putting it in the correct way) It only works till i start driving then naps the little clip.. Any help would be great Thanks Mark
FB/EKForum member 123
Aussie Bob
Re: Trimatic help
Post by Aussie Bob »
Put in a Hydra-Matic ;)
Re: Trimatic help
Is the cable too short (no give)? Also the rear gearbox mount not moving?
Check your engine mount's are not broken.
Sounds like something is moving a fair way to snap that.
minifb
Re: Trimatic help
Post by minifb »
Trev wrote:Is the cable too short (no give)? Also the rear gearbox mount not moving?
Thanks trev,gearbox is not moving. i will replace the speedo cable
Cheers Mark
Doc Bob
Re: Trimatic help
Post by Doc Bob »
Got it sorted yet :?: :?: :?: :?:
#1 Make sure you have the right matching gears (There are two different drive gears and multiple cable gears)
#2 Make sure that you have the cable retaining plate slotted into the machined groove of the cable drive end.....NOT.........BOLTED DOWN OVER THE TOP :shock: :oops:
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
