Wheels for CSR front end
WesternWagon
Post by WesternWagon »
Hey all
Any advise on diameter and or back space on wheels to use on CSR front end with HQ stubs and front mount rack
The standard HQ rims rub on the steering, CSR recon Chev Ralley rims are the go
I want to keep the diameter as small as possible
Gazza
Member : Holden Car Club WA.
:ASRF Member
Re: Wheels for CSR front end
Are they rubbing o the steering arms or the wishbones ? If its just the arms you can space them in to clear - another job the half arsed rod shop should have alreday done ................
WesternWagon
Steering arms are the spacers legal? Will I need longer studs?
The CSR gear has required a lot of tweaking to fit! A bit disappointing really
:ASRF Member
Yes and yes , as long as you machine up a spacer , dont just whack a heap of washers on there ............
CRS gear has needed a lot of tweaking to fit since day one , which would be fine if they actually did something about making it right but for 20 years its been the same :roll: :roll: :roll:
WesternWagon
Cheers, I will look into it. I am told Mr Mag sells spacers.
Gazza
:ASRF Member
No , dont space the wheel OUT , space the steering arms IN .
WesternWagon
Got ya
:ASRF Member
I've had to get my wheels (on the EK and FB) off-set changed to stop this problem.
I asked the wheel joint for a HR disc off-set and they knew exactly what I wanted :D .
WesternWagon
What size wheels did you have to get?
:ASRF Member
I got 14x5's for the front.
HT/G though, not HQ.
Stinky's spacers for clearing wheels 8) ...can't remember what wheels he had on the front though.
WesternWagon
Thanks Harv
I will get some machined up next week looks like about 25 mm will do the trick.
Very tight aroung the calliper.
Off to Perth to pick up the new ute :D pics later today
Gazza
:ASRF Member
