Vacuum Source for VH24 Brake Booster
Stygian
Post by Stygian »
Given that my grey motor has a lumpy cam in it, chances are there won't be enough intake manifold vacuum to run a VH 24 booster. I'm just wondering then if the vacuum pump underneath an FB fuel pump would be up to the task of providing enough vacuum for this size booster. I'd like to run a booster is possible (I'm using EJ brakes) but I don't want to fork out for an aftermarket vacuum pump. Has anybody tried this?
Andrew
Re: Vacuum Source for VH24 Brake Booster
I could be wrong, but it doesn't feel right (the poor old wiper motor pumps struggle with windshields... let alone pulling up a screaming grey :D :shock: ).
Aftermarket pump and perhaps vacuum tank (tank stuffed under a guard with a stone shield?) sounds closer (pricey, though I guess cheap insurance after working so hard on the motor).
Maybe give Hoppers or Burt Bros a call - I guess they've done lumpy cam grey brakes before.
was also gunna sujest vacume tank, although i've run some big cams and never really had any vacume probs
Stygian
Post by Stygian »
Thanks Harv and Mick, sounds like I'm going to have to do some research and maybe a bit of trial and error once the car's mobile.
Andrew
Make sure the handbrake is adjusted properly first, 'cause once it's mobile the temptation to give it a run in the backyard, even with poor brakes, is overwhelming (don't ask.... :oops: :lol: ).
Stygian,
Maybe give ACE (Chris) from the FEFC forum a yell?
http://fefcholden.org.au/forum/index.ph ... 182.0.html
Stygian
Post by Stygian »
I'm not a member of that forum Harv, so I can't send him a PM. Do you reckon you could get Chris' phone number for me?
Thanks for spotting this mate.
Andrew
