used to have a high octane rating, as with everything they gotta f#%k with it so they make more money out of it
think it goes this way LPG is propane? and they figured they can mix it with butane which knocks the octane rating down
on top of this if you can get good LPG you need very high compression ratio to get the benefit from the high octane gas as you need to compress the the gas more than fuel
years ago a mate had an F100 with a 460 on gas running 14 to 1 compression and they reckon it could have benefitted from more comp
plans were for a supercharger till the F truck found it's way up a telegraph pole
