I am doing this for my wife and My wife has little muscles
Ive seen it and it is original...Steve Jackson wrote:I have an EK with original power steering if you need to take a look at the setup!
Steve
You should post some photos of the set up Steve, I would be pretty interested in how they did it back then. The only other power steer system I have seen pre 60 was where a fella modified a Compact Fairlane pillar ram setup. Worked well for low speed but no good at road speeds.Steve Jackson wrote:I have an EK with original power steering if you need to take a look at the setup!
Steve
it'de be a setup off an EH the same as what's on a H/KTG or the same as early chevs a ram typeoldnek wrote:You should post some photos of the set up Steve, I would be pretty interested in how they did it back then. The only other power steer system I have seen pre 60 was where a fella modified a Compact Fairlane pillar ram setup. Worked well for low speed but no good at road speeds.Steve Jackson wrote:I have an EK with original power steering if you need to take a look at the setup!
Steve
Hi Steven, this is on a one of a kind EK Holden and would most certainly be the first power steer Holden.Squirralien wrote:I wonder if it was an experimental trial and maybe only a very limited number were released with it before an official release ???
