Page 1 of 2
Feels like Brakes are stuck on
Posted: Sun Feb 20, 2011 4:14 pm
by tm 50
Parked in the drive Normaly the car would roll a bit on its own , didnt worry to much about it until i drove it , when i took the foot off the throttle it felt as if it was slowing down with a bit of Brake applied , feels as if the brakes are jammed a bit, cant smell anything felt al the rims seemed normal enuff! Before i start seaching for the problem any one experienced this B4 so dont have to fart arse around to much, Its all stadard, drums with a booster assist
Re: Feels like Brakes are stuck on
Posted: Sun Feb 20, 2011 7:29 pm
by Dakam
Take your foot off the pedal. :lol:
Dave.
Posted: Sun Feb 20, 2011 8:09 pm
by Trev
tm 50 wrote: Its all stadard, drums with a booster assist
There's your problem rite there :roll: :lol: .
Posted: Sun Feb 20, 2011 8:12 pm
by tm 50
:lol: :lol:
Thanks Dave!!! I have Now got an FB with ABS, " Automatic Braking System"" no effort required
Posted: Sun Feb 20, 2011 8:15 pm
by tm 50
Farking locals , Great help you guys are
just waiting for the Devil himself for some of his twisted humour
Posted: Sun Feb 20, 2011 9:34 pm
by Devilrod
Hey I resemble that remark :shock: :twisted: :twisted: :twisted:
But seriously thats normal for an FB (forever Braking)............... :mrgreen: :mrgreen: :mrgreen:
Posted: Sun Feb 20, 2011 9:40 pm
by tm 50
Your slipping DR , thought you would have spelt it "breaking"
could be worse Eternally Kactus
Posted: Sun Feb 20, 2011 9:46 pm
by Devilrod
:lol: :lol: :lol: :lol: :lol:
Check all your rubber brake lines and as silly as it may sound tyre pressures. Failing that jack it up and check each wheel while in the air.
Posted: Sun Feb 20, 2011 9:54 pm
by tm 50
Must admit I havent checked the pressures for a while, was going to jack it up tommorrow nite , go through it wheel by wheel, i have a sneaky suspicion that when i had the booster fitted they may have twisted the line on the RHD side
Posted: Sun Jun 05, 2011 4:00 pm
by tm 50
Finally got a bit of time to check the brakes, after having a booster fitted, found out that they left the check valve in, removed it , put it all back together etc
started the car up, same deal, car wont roll, turn the motor off /or disconnect the vacumm and she rolls down the drive, anyone got any ideas, al the lines are where they should be
Posted: Sun Jun 05, 2011 7:17 pm
by matches
is it a remote booster or a firewall one?
Posted: Sun Jun 05, 2011 7:26 pm
by tm 50
Its a Remote
Posted: Tue Jun 07, 2011 12:32 am
by matches
i had one do the same kind of thing but it was a firewall mounted one and it ended up being that the rod going from the booster into the back of the master cylinder wasn't seated into the cupped slot in the piston properly so as soon as there was any vaccuum it pushed the piston a bit (just enough to make the brakes rub and squeek in my case, but it was enough to stop it rolling on the driveway)
Posted: Tue Jun 07, 2011 7:46 am
by tm 50
Spoke to PBR yesterday, they agree that it has to be the booster are going to replace the unit , and test the old one
I'l be interested to see what the fault is
Posted: Wed Jun 08, 2011 1:56 pm
by stinky
Is it the correct booster? There were several (at least 2 anyway) types of boosters, some for drum/drum and some for disc/drum combos. mcl1959 on the FE/FC forum would be able to tell you what is what if no-one else can.
