Alternator bracket to suit grey
Posted: Wed Oct 27, 2010 6:43 pm
by Aussy Edo
Hey Guys,ime chasin an Alternator bracket to suit a grey,going to replace the original Generator(Lucas,prince of Darkness).Any ideas would greatly be appreciated.cheerz
Edo
Re: Alternator bracket to suit grey
Posted: Thu Oct 28, 2010 12:25 am
by sloth
use bosch alternator inbuilt reg with 2 mounting legs no brackets needed or welding think xf &*#@ ones you can use rear generator bracket the one that bolted to eng block for rear leg using longer bolt and spacer tube front leg fits to engine block when you remove geny mount bolt just drill front leg to fit larger front bolt space alt forward with some washers to line belt up mount front first so you know how long spacer tube is for rear i have the belt number if you use this and need it
Posted: Thu Oct 28, 2010 11:01 am
by thropzed
Edo, I used two generator brackets on the bottom and the stock tension bracket on the top. Drop in and have a look! Also this has been done before so a search might yield what you need
Cheers Theo Z.........................
Posted: Fri Oct 29, 2010 6:33 pm
by Aussy Edo
Hi Guys,thanx for the info,ile give you a ring around chrissy Theo,ive got a couple of weeks off so ile try an get round for a captain cook!!
Edo :wink: :P :D
