Alternator bracket to suit grey
Aussy Edo
Post by Aussy Edo »
Hey Guys,ime chasin an Alternator bracket to suit a grey,going to replace the original Generator(Lucas,prince of Darkness).Any ideas would greatly be appreciated.cheerz
Edo
One Day Hopefully!!
sloth
Re: Alternator bracket to suit grey
Post by sloth »
use bosch alternator inbuilt reg with 2 mounting legs no brackets needed or welding think xf &*#@ ones you can use rear generator bracket the one that bolted to eng block for rear leg using longer bolt and spacer tube front leg fits to engine block when you remove geny mount bolt just drill front leg to fit larger front bolt space alt forward with some washers to line belt up mount front first so you know how long spacer tube is for rear i have the belt number if you use this and need it
thropzed
Post by thropzed »
Edo, I used two generator brackets on the bottom and the stock tension bracket on the top. Drop in and have a look! Also this has been done before so a search might yield what you need
Cheers Theo Z.........................
FB/EK Car Club of QLD.
Aussy Edo
Post by Aussy Edo »
Hi Guys,thanx for the info,ile give you a ring around chrissy Theo,ive got a couple of weeks off so ile try an get round for a captain cook!!
Edo :wink: :P :D
One Day Hopefully!!
