With the two drum to drum diffs (FB and HR) side by side it was a good opportunity to compare them.
Widths are identical
Centre casting appears identical - and GM parts bible confirms it with old FE to EJ #7408407 superseded by #7421813 which according to the manual will fit 48 to HR. #7421813 coincidentally is the part number for EH, HD, HR
Spring saddle spacing is identical although the pressings are vastly different which begs the question - is the HR mounting stronger, stiffer, better?
Backing plate mounting flanges on housing appear identical (meaning HR backing plates should bolt straight on meaning the self adjusting slave cylinders etc should all just bolt in)
I can't see any reason why you couldn't leave the housing and the centre in place and swap the brakes and shove the FB EK axles back in?
I guess what I am getting at is, can the FB EK housing and centre stay put and the HR brake assemblies be substituted along with their smaller slave cylinders?
Seems like it would save some jigging around and you wouldn't have to search for the elusive shock mounts or root around with the bump rubbers ?
While stuffing around we also measured a Torrie banjo housing and it is approx 70mm narrower - if that helps anyone
Comments and ideas please ....
Dave Mac
