Trev wrote:Very nice, how would you go lowering it
, Trev
No idea
It's the last separate chassis Jaguar - has a massive big cruciform thing - 6-8 inch section, boxed in, multiple cross-braces and a huge X-shaped brace across the main area. Chassis is thick enough to hold the drivetrain - there's no transmission tunnel behind the box, prop shaft runs inside the chassis.
Double-wishbone independent front end with torsion bars – front ride height is adjustable ex-factory.
Rear is a pretty standard live-axle (Salisbury) with semi-elliptic springs.
Telescopic shocks front and rear.
Biggest issue with dropping the ride height would be the massive rear overhang and the tire size: 16x6.5 is ken-huge.
Jaguar were still building decent cars back in the 50’s and 60s – this is when they were still winning tarmac rallies and endurance races like Le Mans – their stuff was bullet-proof. Just don’t ask about oil leaks... In the 50s they were still hand-matching pistons to the bores to get the tolerances right. In the 70s, they were still using the machinery from 1948 (bought second hand!) and they’d stopped hand-building engines and just blew the tolerances out so the things would fit together, however sloppily. They’d also bored the engine out from 3.4 litres to 4.2 with siamesed wet liners and changed the bore spacing but didn’t bother to alter the head, so the combustion chambers aren’t even centred over the bores... They also stopped bothering to flow the heads properly which meant the best 3.4 litre spec engines from 1958 were producing more real power than the 4.2 litre engines from the 1970s, regardless of what the spec-sheets may have been claiming.
1970s and British Leyland was when everything went to hell. Didn’t get better until F#rd bought them and upgraded everything to “F#rd” quality. With Jag prices....
Now Tata India own them...
I'll stick to 60's and earlier stuff when buying British, thank you very much...
