Where do they go
Posted: Wed Sep 08, 2010 8:55 pm
by BILLY BLACKARROW
Hi ya all
I am fitting HZ disc to front on HR stubs with HZ drum on rear my problem is the disk calipers do they mount front or rear of the disk any help
THANKS BILLY :arrow:
Re: Where do they go
Posted: Wed Sep 08, 2010 9:41 pm
by stinky
They go where ever they fit :lol:
and where the bleed nipple/valve is the highest point of the caliper.
BRAKE FAIL LIGHT
Posted: Thu Sep 09, 2010 8:35 pm
by BILLY BLACKARROW
Anyone have to put brake fail light on dash for Rego reasons V8 conversion and where did you put it that didn't look out of place.Garry maybe ??
BILLY :arrow:
Posted: Fri Sep 10, 2010 9:35 am
I have to do mine for rego, and it worries me trying to find somewhere that doesn't look like an "add on" from SuperCheap :x .
Plan at this stage is to pull apart the Oil/Gen/Temp idiot-light guage set, and add an extra red jewel to the assembly. Theres an evil part of me that says I should add an extra light for a nitrous arming switch :twisted: , but the sensible part of me says theres enough stuff to do on the wagon now to keep me busy.
Theres a post somewhere here that Rosco did on replacing the jewel lights with LEDs, probably where I'll start. Will have to redo the "glass" lettering, but would have to do that anyway (want to tart up my gauges as per Matty Martin's process).
Posted: Sat Sep 11, 2010 9:11 am
by gareth
which engineer you using for your project harv?
Posted: Mon Sep 13, 2010 2:28 am
PM sent re: engineer.
Posted: Mon Sep 13, 2010 1:37 pm
by FCOV6
BILLY BLACKARROW wrote:Hi ya all
You are using HZ calipers on HR stubs with adapter plate's i'm guessing ?
Posted: Mon Sep 13, 2010 8:08 pm
by BILLY BLACKARROW
Drop spindles sorted that problem but brake fail light is still a problem ANYONE
BILLY :arrow:
Posted: Tue Sep 14, 2010 6:15 pm
by Thommo
I have never heard of anyone having to put
in a brake fail light ever :o
If the brakes fail, your going to know about it anyway :roll:
tell him he's dreaming :wink:
Posted: Tue Sep 14, 2010 7:35 pm
by BILLY BLACKARROW
It's a little late by then Thommo
BILLY :arrow:
Posted: Wed Oct 06, 2010 1:21 pm
by FCOV6
BILLY BLACKARROW wrote:Drop spindles sorted that problem but brake fail light is still a problem ANYONE
BILLY :arrow:
It used to be (or still is ) law that you fit a brake fail light in the system when upgrading brakes, you will need to use the HQ-HZ distributor block that has the plastic plug in sensor.
Re: BRAKE FAIL LIGHT
Posted: Wed Oct 06, 2010 3:37 pm
by Cal
BILLY BLACKARROW wrote:Anyone have to put brake fail light on dash for Rego reasons V8 conversion and where did you put it that didn't look out of place.Garry maybe ??
BILLY :arrow:
Didn't some EK's come out with a handbrake light on the dash? Maybe you could do something similar with the brake fail light, and it won't look out of place
Posted: Wed Oct 06, 2010 9:21 pm
by BILLY BLACKARROW
Cal
Any more info on handbrake light first I have herd of them on EK's very interested
BILLY :arrow:
Posted: Mon Oct 11, 2010 1:06 pm
Billy,
Check with Smooth on the OldHoldens forum - from memory he has a hand brake warning light for sale, and may part with some photos/fitting instructions.
