Where do they go
BILLY BLACKARROW
Where do they go
Post by BILLY BLACKARROW »
Hi ya all
I am fitting HZ disc to front on HR stubs with HZ drum on rear my problem is the disk calipers do they mount front or rear of the disk any help
THANKS BILLY :arrow:
BILLY BLACKARROW
stinky
Re: Where do they go
Post by stinky »
They go where ever they fit :lol:
and where the bleed nipple/valve is the highest point of the caliper.
BILLY BLACKARROW
BRAKE FAIL LIGHT
Anyone have to put brake fail light on dash for Rego reasons V8 conversion and where did you put it that didn't look out of place.Garry maybe ??
BILLY :arrow:
BILLY BLACKARROW
I have to do mine for rego, and it worries me trying to find somewhere that doesn't look like an "add on" from SuperCheap :x .
Plan at this stage is to pull apart the Oil/Gen/Temp idiot-light guage set, and add an extra red jewel to the assembly. Theres an evil part of me that says I should add an extra light for a nitrous arming switch :twisted: , but the sensible part of me says theres enough stuff to do on the wagon now to keep me busy.
Theres a post somewhere here that Rosco did on replacing the jewel lights with LEDs, probably where I'll start. Will have to redo the "glass" lettering, but would have to do that anyway (want to tart up my gauges as per Matty Martin's process).
gareth
Post by gareth »
which engineer you using for your project harv?
PM sent re: engineer.
FCOV6
Post by FCOV6 »
BILLY BLACKARROW wrote:Hi ya all
You are using HZ calipers on HR stubs with adapter plate's i'm guessing ?
BILLY BLACKARROW
Drop spindles sorted that problem but brake fail light is still a problem ANYONE
BILLY :arrow:
BILLY BLACKARROW
I have never heard of anyone having to put
in a brake fail light ever :o
If the brakes fail, your going to know about it anyway :roll:
tell him he's dreaming :wink:
BILLY BLACKARROW
It's a little late by then Thommo
BILLY :arrow:
BILLY BLACKARROW
FCOV6
Post by FCOV6 »
BILLY BLACKARROW wrote:Drop spindles sorted that problem but brake fail light is still a problem ANYONE
BILLY :arrow:
It used to be (or still is ) law that you fit a brake fail light in the system when upgrading brakes, you will need to use the HQ-HZ distributor block that has the plastic plug in sensor.
Cal
Re: BRAKE FAIL LIGHT
Post by Cal »
BILLY BLACKARROW wrote:Anyone have to put brake fail light on dash for Rego reasons V8 conversion and where did you put it that didn't look out of place.Garry maybe ??
BILLY :arrow:
Didn't some EK's come out with a handbrake light on the dash? Maybe you could do something similar with the brake fail light, and it won't look out of place
BILLY BLACKARROW
Cal
Any more info on handbrake light first I have herd of them on EK's very interested
BILLY :arrow:
BILLY BLACKARROW
Billy,
Check with Smooth on the OldHoldens forum - from memory he has a hand brake warning light for sale, and may part with some photos/fitting instructions.
