no handles
no handles
one day i'll put up some photos but while i was in sydney over the weekend we shaved the door handles and boot lock off my ek sedan
Same colors? Hope all turns out well, Trev(AUST)Mod wrote:Yeah I will give the painting a go. My dad painted our 49 prefect in our garage, so I figure why not as we have all of the gear. Armed with Rosco's tips, I will venture into the painting world
here you go
in the first pic the little tab that is circled needs to have a peice welded on with a hole in it or put a hole in it, that can be seen in the second pic all you need to do then is attach a rod pointing to the top of the door i used rear door lock rods, drill a hole in the top of the door around the same position as the inner door lock (on front doors) but on the outside, poke rod through put a nob on it, remove external handel weld up holes job done
one problem (that doesn't worry me) you can't lock the doors as the tab that now opens the doors attaches to the inner mechanism so when you press it down it unlocks the door
that's all i do open from inside, not sure of the legalities of that though
NSW rules say have to be able to manually open door from outside
it kinda sucks to be kool (doesn't help being a tight arse) shaved the tailgate on the wagon aswell so now to open it i have to open the front door to open the back door to get in and reach over to open the tailgate from inside
