Cheers Nath, im trying man... just seem to be going no where with it. Everythings pretty much ready to go though. So i guess when it comes time to put it back together it shouldnt take tooo long
sweet, yeah there the ones i drew up from his kit! so if you look at the ones in my FB EK section thats sort of how they should turn out, the end that gets welded to the Leaf spring mount, it helps if you kick them in a little and make them squeeze fit in before you weld them, so also check the width inside that mount
cheers
Nathan
Foundation Member
yeah in the first few pages of my thread, i'm not using the 'Y' frame plates thought as i dont need them (keeping them for future possibly), check with your engineer first dude might save you making something not required
cheers
Nathan
Foundation Member
Yeah same, i wont be using the Y frame part either...
I dont think you have to, but i want to do the chassis kit anyway man, i gotta make the gearbox crossmember so i might as well do it so it bolts to the chassis kit instead of the floor. Bit of messing around but its better that way, plus i plan of putting a bit more power through it later on
Brodie wrote:Yeah same, i wont be using the Y frame part either...
you and i think a like
cheers
Nathan
Foundation Member
