202 rocker cover
nate_138
202 rocker cover
Post by nate_138 »
hey there chasing a 202 rocker in brisbane only have a 186 one at the moment need one to stop the rubbing! if anyone has one original or aftermarket would be great! cheers!
Re: 202 rocker cover
Thought they were all the same :? .
Do you have roller rockers and they are fouling on the rocker cover ?
If so there are aftermarket rocker covers that are taller to allow room for them.
This is a classic example of the "if you modify one thing you must modify two more to make itwork " theory :shock: :?
nate_138
Post by nate_138 »
I also thougtthere wouldn't have been any difference but when you compare the 2 stock covers there's about 3-4 mm difference in the curve of the front and rear of the cover. So the rocker at either end is rubbing getting hot and cracking.
I have one here to compare the difference but it's not good enough to use.
