diff help
basic.green
diff help
Post by basic.green »
help i need help with my diff
i cant get my Tyres to fit :roll: dose any one no some one that can cut my diff down buy a inch or change a volvo diff to fit
or got one for sale
i was so close to the end and now this
i thought i could get smaller tyres but no good i have gone to a 195 and they still rub :roll:
any help would be great
building the dream Rick
Re: diff help
What diff are you using ?
Re: diff help
Just change the wheel off-set :idea: .
axeman
Re: diff help
Post by axeman »
call Rodtech in adelaide they can cut down your diff for $400 -$500 with resplined axles or go lc-lj torana diff with leaf spring hangers welded on
Cheers Axeman
IF ITS NOT OVER POWERED ITS NO FUN
PRAISE THE LOWERED
ek61
Re: diff help
Post by ek61 »
rick it all depends on your off set
you have your wheels so its going to make it hard to find somthing to fit perfect unless you get one cut to size
you could try a volvo diff or torana diff but again it depends on off set
ask thommo if you can try your wheels on his fb to see if they will fit he has a hr diff cut down to torana size diff
or camron he has a volvo diff see if they fit either of them and go from there
i have there numbers im sure they would help out
cheers dave
***just cruise***
(AUST)Mod
Re: diff help
Post by (AUST)Mod »
IIRC, I think that volvo diffs are about 1" shorter on each side and LC/LJ torana are about 1.5" shorter on each side. Don't quote me on that though!
Also, have a look at olskule's ek for an awesome example of guard flaring.
Re: diff help
I have a volvo diff here and it's the same as HR, don't know about different models.
stinky
Re: diff help
Post by stinky »
If you can get hold of a Volvo or Torana diff (whichever suits) Lance Walker can weld on the spring mounts for $100, he did the Volvo diff I got from Dave a while back (http://www.walkerchassis.com.au).
Torana is shorter, Volvo is stronger but I am not sure of the width, the diff I have doesn't have the discs on :roll: .
basic.green
Re: diff help
thanks for all your help :mrgreen:
blacky hr diff
trev off-set is to late i have the wheels all ready
axeman thanks i will give them a call
dave sounds like a plan i will look into it
adrew thanks i will go to wreckers and check
thanks stinky i will look into it
i did end up buying some smaller tyres 185x60x15 :oops: and they clear but a smaller profile ok for now
hopeing for early october a mates birthday
thanks again 8)
Re: diff help
Find yourself an LJ housing and axles - you can use your centre in it.
basic.green
Re: diff help
thanks Blacky 8)
Re: diff help
Post by mrs ratbox »
Blacky wrote:Find yourself an LJ housing and axles - you can use your centre in it.
get under and do some measuring first as you may not have the room on the inside, from memory the LC/LJ diff is shorter by 11/2" each side so make sure you have that to spare on the inside
basic.green
Re: diff help
will do ratbox 8)
