Wire type - hose clamps
samprinci
Post by samprinci »
G'day all.
quick question, has any 1 use the original wire type hose clamps for radiator hose???? just wanted to c if anyone had bad experiences or can recommend they work fine???
hers a pix for reference
TA
Sam
www.fbekholdennsw.com
samprinci
Post by samprinci »
Thanks gain tim,
do u mean "thay can be a B%&^**# " because they dont work properly & leak?
FB MAD
Post by FB MAD »
He probably means they can be a bastard to squeeze when trying to remove and install as they squirm around when you squeeze them with a pair of flat face pliers.
samprinci
Post by samprinci »
OH! thanks FB MAD.
samprinci
Post by samprinci »
Does any body have any of these clips??? Rang Rares n they dont, nor do Spectrum???
need 2 for the radiator.
I'll put a post in parts wanted too.
TA
blue ute
Re: Wire type - hose clamps
Post by blue ute »
They're called Corbin Spring Hose Clamps, sometimes the'yre on ebay, rarespares have them listed in their online cattledog https://rsp-secure.com/rarespares/ - Browse by type - GM - Holden - FE FC - heater and engine bay - scroll down
samprinci
Post by samprinci »
blue ute wrote:They're called Corbin Spring Hose Clamps, sometimes the'yre on ebay, rarespares have them listed in their online cattledog https://rsp-secure.com/rarespares/ - Browse by type - GM - Holden - FE FC - heater and engine bay - scroll down
Thanks Blu ute, but the FB radiator 1's are 1 1/2'. rares are;HOSE CLAMP KIT WIRE TYPE 3/4" OD (4 PCS)
Got them off ebay dude.
thanks for your help any wayz.
