Rusty EK wrote:G,day All
Have just started rebuilding an EK ute , floor is totally rusted out and am going to put a chassis through from front to back , what I want to know has anybody fitted a Jag IRS rear end into an EK before and if so do you have any tips for me
Chris
Chassis? Are you thinking of a full chassis or a strengthening kit.
Jag rear ends found their way into quiet a few early Holdens in the late 70's and 80's. Are you after looks, as in lots of shinny moving bits that the people behind you can see going around.
I hope you have deep pockets because the modifications to make it fit and rebuild alone will not be cheap. And you will come up against another problem if you want to chrome plate such parts and use them for street use.
Are you going to stretch the wheel base for your cab extension
With that and the Torana front end, plus your powerplant upgrade you may be looking at an ICV for registration. And that is something I dont think you will be prepared for.
Your wish list is not exactly clear in all the details, and before you do one bit of work. Ring an engineer, if he is interested in doing your project get his approval or requirement list for legal registration on paper and signed by him.Along with a letter from your State registration department with their approval on this build.
Then you can start building.
