Valerie the EK Standard Sedan
Re: Valerie the EK Standard Sedan
I'm guessing flexplate to mate grey motor and Trimatic.
Which ring gear does it use: red or grey? It determines which starter motor you have to use . . .
Red motor starter motor. Its a holdenman one.
hallelujah
mph
Post by mph »
Been on there for a while ay
FB-Special
Big block 161 :lol:
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
What's that foreign cable coming out under the bonnet hinge?
Hq accelerator cable going to the Holley.
Thought it looked familiar. Looks like they used an original trim clip hole. Had one in my standard sedan but didn't like it. Eventually ran the cable from the lever on the end of the original pedal which worked pretty good. Electric kickdown button under original pedal.
Trimatic gate off HX column auto and 7420346 neutral safety switch
Good setup
Yeah easy fit up
Though the selector is moving a foot closer to the driver on this one because I’m putting in r&p steering
Will be interesting to see how it works Patrick.
mph
Post by mph »
Will the neutral safety switch work on the ek column? , you can buy new ones to suit trimatic and ek column
FB-Special
Big block 161 :lol:
Holley sniper EFI.
HJ one bolts up and works as it should. Park and neutral only power to starter solenoid. Reversing lights. If you wanted to be tricky maybe you could run a relay off the brake lights so you only get starter when your foot is on the brake as well, like a proper flash modern car.
Working on the hidden fuel filler
