Neil's FB Station Wagon
Re: Neil's FB Station Wagon
FireKraka wrote: Tue Jun 23, 2026 1:36 pm Purchased one of the Chinese GPS speedo's that Brett purchased from eBay, looks pretty good but a little worried that it does not sit on Zero unless it needs power to zero, will see when it goes in.
It will go to zero once it's connected up. Getting the rev counter callibrated is the hard bit. You will need another rev counter to check against as you go. There are an infinite amount of combinations to use, not like the old switch for 4,6 or 8 cyls. It will keep you busy. The speedo is very accurate and easy to fit and wire up.
Thanks Brett I came across the tacho issue when I was doing the conversion on my FC Sedan the commodore signal pick up from the alternator from memory and is weird 5 square signal or something :crazy: , can't remember, anyway I can get a converter I believe that goes into the signal supply wire that converts the signal, I'm still along way off of there at the moment.
Hey Greg it isn't the adapters that are the problem it is the callipers, where I have ground the calliper in the picture is to flatten the mounting area and so that when it mounts to the stub axle it mounts flat to the mounting face of the stub and doesn't kick it over to jam on the rotor.
I'll take a photo of the other calliper to show what I mean
Hi Greg see the photo of the calliper that I haven't ground, you can see the casting is close to the mounting holes.
Because the flange of the drop spindle where the calliper mounts is so different (larger) that you need to give the calliper the clearance otherwise the mount holes don't match up and the calliper fowls on the rotor.
Image (10).jpeg (255.66 KiB) Viewed 2325 times
Finally got the brake upgrade sorted after some modification which you have to do anyway to get the VT callipers to fit the drop spindles.
The rotors are VT V6 but I have drilled them out to 14mm for the studs because the rear is VE which are 14mm and VT is 12mm so I wanted to have same studs front and back.
Just need springs and I can put the front suspension together.
Image (6).jpeg (245.01 KiB) Viewed 2234 times
Image (7).jpeg (249.44 KiB) Viewed 2234 times
Looks good Neil,
Expert now mate !
Hey Greg you know what an Expert is? X is an unknown quantity and a spert is a drip under pressure :lol:
Anybody got a set of standard original HR front springs by chance???????
WesternWagon
Post by WesternWagon »
FireKraka wrote:Anybody got a set of standard original HR front springs by chance???????
I may have
Member : Holden Car Club WA.
:ASRF Member
Thanks Gaz however I have been able to source a pair from a mob in Victoria.
I rang Damien at Warburton Early Holden Parts (he couldn't help :roll: ) he put me onto Chris at Dinkum Autos in Cheltenham Vic, Chris was really helpful and went out of his way to help me get a set of springs really fair price and they are already on there way :clap: :clap:
Springs arrived yesterday from Vic, they had been blasted and primed, I gave them a quick coat of paint.
Image (8).jpeg (246.25 KiB) Viewed 2081 times
They have the holden part number on them!!
Image (9).jpeg (141.77 KiB) Viewed 2081 times
I now have all of the parts for the front suspension, hopefully I can get it all together before the Boss and I head overseas later this month.
Owe and they are straight it is just the way they are sitting when I painted them and took the photo :crazy: :crazy: :lol:
Everything ready to go :clap: :clap: :clap: :clap: :clap: :clap:
Image (10).jpeg (261.68 KiB) Viewed 2045 times
Nice work mate. Grease nipples on the ball joints? The uppers on our sedan don’t have any and I’m wondering if that is how they are making them now.
Thanks Clay
Pretty sure the uppers have grease nipples and I haven't put them in the bottoms yet as you can see.
WesternWagon
FireKraka wrote:Thanks Gaz however I have been able to source a pair from a mob in Victoria.
sweet Image
:ASRF Member
