Wilma FB project
Re: Wilma FB project
Brett,
There are a couple of approaches. One is to rat an old metal Utilux fuse holder for the short piece. The other is to break an instrument lamp, dig the glass out, and re-use the base. Solder the centre conductor of the coax to the inner terminal, and solder the braid to the metal body. just check that an instrument lamp is the right size to fit the radio's antenna socket first.
Good ideas. Many thanks Rob.
Mine was modern type. Got from thommo. Must be EK!
Front seat in today and outer rubbers and Crupi sill trims on passenger side. Minus 7 this morning, so took a while to get started🥶.Image
Brett027 wrote: Mon May 31, 2021 4:29 pm Minus 7 this morning, so took a while to get started
How the hell do you manage to survive in weather like that :gasp: :gasp: :gasp: :gasp:
62ekute
State: ACT
Post by 62ekute »
Blacky wrote: Mon May 31, 2021 6:21 pm
Yeah Brett, I'll leave you with it - just booked a flight back to Perth. Patrick
Wooses (is that how it's spelled?)
Can I come too Patrick🙂?
Actually I think my thermometer is broken. Probably wasn't as bad as that, but the melting ice on the tin is a pain as it drips on you....
62ekute
State: ACT
Post by 62ekute »
minus 6.3 was the official Canberra temp
$*#@ the weather, that seat looks the goods.
Thanks Clay- looking forward to putting the door cards on for the full effect. Kate and I had a sit on it at lunch time. For me its been 55 years since I've sat in an FB😀. Kate has never sat in one.
Gold moment. Where’s the pics?
Another question. These two bailey channel fittings came off front doors. Which one goes on which door and which way is up? The holes allow them to fit either door and either way.ImageImage
Brett,
Is Wilma an early FB? The longer inner bailey channel is (guessing) a leftover from FE-FC production.
Went downstairs to check "Found Object"'s front doors. The longer end is at the bottom.
62ekute
State: ACT
Post by 62ekute »
hi Brett...up the way you've got them...both sides the same. Patrick
Wow. Many thanks Rob, Patrick. This response is so helpful😀.
Bit of a cleanup and paint on the way.
