Cameo Beige EK (Rust Repairs done)
FB MAD
Post by FB MAD »
Also look under heading "General Sharing Advice and Experience" section and up the top of that section page there is a sticky thingo titled "Very Handy Site".
Click on that and it will go to the DOTARS site and the National Code of Practice for Light Vehicle Construction and Modification.
Most state rego mobs use this as a basis for their respective criteria for modifications and then tweak them to suit.
Most of the info you need will be there.
VS355
Post by VS355 »
Thanks FB MAD Looks like i have a lot of work ahead of me. I will start calling around tomorrow to see what A.C.T rego requires.
Another Question: Is it possible for me to get a trimatic to work off my standard column?
FB MAD
Post by FB MAD »
Pretty sure they will but the gearshift position indicator will be wrong as Hydromatic shift sequence is different to traumatic shift sequence.I think Trev is, or was going to a trimatic, maybe he or someone else running trimatic with original column can shed a bit more light to your question maybe.
matches
Post by matches »
my ek is running a trimatic and red 186 at the moment, my trimatic is hooked up to the standard column, i can take a few pics on the weekend for you of how the linkages go and anything else if you like,
L&K
minifb
Post by minifb »
Hi Why dont you do the t700 conversion to 202 red motor....Im doing one at the moment pretty easy so far..Cheers Mark
FB/EKForum member 123
NoMAD
Post by NoMAD »
minifbvan wrote:Hi Why dont you do the t700 conversion to 202 red motor....Im doing one at the moment pretty easy so far..Cheers Mark
Second....
NoMAD
If it's so easy, why is it taking you so long to do it :lol: , Trev 8) .
minifb
Post by minifb »
Cause ive been away from home for nearly 5 weeks :roll: :roll: :roll: :lol: :roll: :lol: :roll: :lol: :roll: Cheers Mark
VS355
Post by VS355 »
Matches: If you get time to take some pics of your linkages that would be very much appreciated :D
Minifbvan: I think i will go with the t700 eventually but at the moment i'm trying to do as little as possible to get it driving and registered. I have a VP Commodore as my everyday driver which i can dismantle when the EK is registered :) .
Better crack the whip on your old man then :shock: , Trev 8) .
VS355
Post by VS355 »
On the weekend i went out to my dads work to pay my baby a visit and to get some detailed pics of the trouble spots on my car. Let me no what you think :) .
All of the rust is on the left hand side :o i don't know why :?:
The nice bonnet hole is from the fan blade :?
EKK001
Post by EKK001 »
Cause when you park on a road, it cambers to the left so all the moisture tends to sit on that side...........i think.
Looks in good nic to me, Trev 8) .
If thats the worst of it you are in for an easy ride !
Doesn't look too bad at all. Your call as to how far you go.
As for the auto, I run a traumatic through the standard column and eventually plan on the t700 conversion which will also be column shifted.
