LS1EK
will1mc
Re: LS1EK
Post by will1mc »
ok cool what part number is that sump or link? its hard to find. Thats true about the aircon ill look into that now
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Holley part number Holley GM LS Engine Swap Retrofit Oil Pan Kit LSX LS1 302-1
There is a muscle car performance one (i think is the name ) but its is bigger. Have a search via google, go on the summit performance parts site and ask for a free catalogue, its has everything in it you could need. There are quite a few mobs in US that are doing bottom mount air con kits that use a sanden min comoressor. I reckon it will fit down on the drivers side front and it appears that there are alternator kits as well.
Sent from my LG-K500 using Tapatalk
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
New floors fabricated and fitted, need to run the through the bead roller, Fire wall next and the the tunnel followed by the boot, so glad i cut out what had been done as the new floor sits flat over the whole floor area, happy days ImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Mini aircon pump roughed in, tick.ImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
So i ended up raising the motor slightly, 10mm so the air con pump had some more clearance at the back of the pump. Also repaired some rust along the top of both seals and fitted the gearbox mount.ImageImageImageImageImage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Fire wall started along with the foot well, new column on its way.ImageImage
Re: LS1EK
keep it coming shagger, the good weather is nearly here 8)
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
I think it arrived this morning Blacky ImageImageImageImage
D-MAN
Re: LS1EK
Post by D-MAN »
What a view :thumbsup:
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Right so started running some beads into my floor pans and now have floors pans that are warped and twisted due to the material shrinking where the beads are.
Googled some info and now know that i should had ran the material through a English wheel to stretch the material. This is okay if you have a English wheel!!
I found another youtube clip where the guy marks both sides of the plate and pre-rolls the back of the plate first with the bead roller putting a very small groove in the plate before turning thd plate over to finish the job.
Looks like i had better get the hammer and dolly out to see if i can straighten the plates before going any further.Image
Re: LS1EK
Always good to learn something new. I saw one of those English wheels on gumtree the other day for a couple of hundred.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Yeah just wished i had known before i started. I have some serious hammering to do to get the panle straight again.
Re: LS1EK
Brand new on EBay for 199$ +$25 postage
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Errol62 wrote:Brand new on EBay for 199$ +$25 postage
I will try reverse beading method first, dude on youtube swears by it.
TAZ
State: TAS
Re: LS1EK
Post by TAZ »
Some success i think they will both be useable.ImageImageImage
