Fingers 327sbc and T400 FB Project
fingers
Re: Fingers 327sbc and T400 FB Project
Post by fingers »
my70wg wrote:its your section, you can post as much as what you want!!
looks good man!
aidan...
Thanks mate ....Fingers :thumbsup:
fingers
Post by fingers »
Devilrod wrote:Whoa flashbacks!! Floors are fun huh! Best time to do them and you won't regret it, as much as it sucks now. :thumbsup:
Thanks guys .......fingers
fingers
Post by fingers »
Got all the floors welded in today .... :D :D ...now the grinding starts ....grinding ,grinding more grinding .............the only other rust in the floors is around the drivers side seat mounting bolt holes and near the back set mounting on the drivers side ...I just cut some pieces from the old floor section belted them to shape and trimmed them to size and welded in as per photos ....floors are all now rust free ...just grinding , grinding . :roll: :roll: .
Fingers grinding....
welded in
Rust around rear set
plated and welded
Plated and welded in ....all rust in floors done .......
muza
Post by muza »
Lookin good mate!!
Floors take ya long? Mines gone in the same spot as yours, behind the drivers floor pan
Stock as a rock
Not so stock
Nice one Fingers :thumbsup:
fingers
Post by fingers »
muza wrote:Lookin good mate!!
A day to cut them out and 1 day to clean them up 1 day to weld them in and 2 days grinding to clean them up ...most of the work was done by my panel guy .....the cleaning up and some rust panels and some prep by me but my welding ability is not quite up to welding 1.2mm panel steel without it looking like the cocky shite on it .....Fingers
muza
Post by muza »
:thumbsup: :thumbsup:
Hopefully.......hopefully ill get mine started this weekend.
Got some wiring issues to sort out on my bike......me and electrical systems dont see eye to eye.
Hoping its a 5 minute fix, probaby take me all weekend :roll: :roll:
Stock as a rock
Not so stock
Great work Fingers. Isnt' grinding back welds fun... :roll: :thumbsup:
Go for it Bill !!!!!!!!!!!
WayneXG95
Post by WayneXG95 »
Wish I had those skills.. :(
Awesome bill... :D
fingers
Post by fingers »
Didnt do any grinding today , but sat the larger transmission tunnel from CRS in and decided to fit it ........I dropped the tunnel on the floor and got centre of the old tunnel and centre of the new tunnel in line then trimmed the new tunnel to fit neatly on the floor and measured from side of tunnel to the outside of the car to make sure its all centred then...tek screwed it into position ...drew around the new tunnel then drew inside the line so there would be an overlap on the underside ...drilled the new tunnel for plug welding on top and the underneath over lap was cleaned up for a full weld .............The hole that is still there was put in by a previous owner probably for a toyota 5 speed tunnel ...anyway went to one of the donor cars and cut out a repair section will get it in next week sometime
Repair section
Got the subframe back from the sandblaster The Panel guy got it in etch prime I cut some rust repair sections from one of the donor cars ...should do the job just beaut .other than the rust around the battery box area it is fairly rust free the legs are all excellent ...will fix the rust and trail fit it ,so we can trail fit the dummy motor and box and get the engine mounts and gearbox mounts all sorted ......
zl296
Post by zl296 »
nice sandblasting job by midge....
what about a free plug for....drouin protctive coatings fingers....
tried to ring you today.
need fb pass quater mould,& pass mould between back door & window...
home monday?
:thumbsup:
jarvo
Post by jarvo »
yeah i dropped the CRS tunnel over the hole and thought the previous owner cut too big, then i thought how the hell am i going to fix that???? great to see you have worked it out... Keep the posts coming mate
yep... someday...
DOLLER
Post by DOLLER »
Haha Done the same thing myself! :roll:
fingers
Post by fingers »
Got the day off so hooked in to it again ...finished welding the inside floors and tunnel inside and under.... grinding was the next job .. all the grinding is done except the under side of the floor panels ..get them done this weekend maybe ....started to fit up the subframe ...but had a few problems with the inside 9/16 bolt that goes in from the inside of the car and is screwed into the subframe thru the firewall ..the only ones without nuts ...if ya know which ones I mean ...ANY IDEAS TO MAKE THIS EASIER ....Ordered my diff housing 1360 mm from disc face to disc face ....using &*#@ rims with a back space of 4" and 1/2" and 7" wide ....hope this does it .... it could get exspensive .....
The underside of the tunnel
The panel Guy started filling the hole in the tunnel
Got these bolts in but couldnt get that 5 th one from the inside .......
