FB ute
Re: FB ute
In the Shed wrote: Sun Mar 02, 2025 8:08 am Good job on the wipers, they can eventually drive you nuts with a clunk & knock in operation. Opportune time to fix whilst the heater goes in.
I have an intermittent control I am going to fit to the Ute the same as I have on the sedan……. one day 🤔
I have a couple of HJ-Z units here that would be easy to adapt , what have you used ??
Re: FB ute
Cruise control- some assembly required ……Image
Re: FB ute
Thanks Blacky. I’ve looked at the command ones. That one doesn’t look that old and has the magnet pick up.
Re: FB ute
Errol62 wrote: Sun Mar 02, 2025 5:24 pm Thanks Blacky. I’ve looked at the command ones. That one doesn’t look that old and has the magnet pick up.
same as what i just put in my hiace, they're still a few years old and command don't have kits any more they can't get the vac modulators, they have everything except them
Re: FB ute
Well I hope the bloody thing works , made all the brackets etc today - started with a CAD template as usual ….
… got that bit close to right
Then transferred to steel and bent it up
Did final fettling and made a brace to go behind it
Re: FB ute
Then on to the pickup bracket - had to make it longer on both planes so made a bracket and welded it on
Glued on the new bits plus a couple of braces
Next !!
Need a cutout switch for the clutch pedal and brake pedal to deactivate the thing so used a standard brake pedal switch and mounted it similar to the stock brake pedal
Used a donor pedal box to experiment on before taking to the one in the ute
Re: FB ute
Like a bought one —
Painted up all the brackets then went and mowed the lawns and did some socialising ImageImage
Re: FB ute
if you don't have instructions and need some i'm sure i have mine in a safe place, problem will be as usual trying to find the safe place i put them :roll:
Re: FB ute
Nice work old bean.
Re: FB ute
Mick wrote: Mon Mar 03, 2025 8:52 pm if you don't have instructions and need some i'm sure i have mine in a safe place, problem will be as usual trying to find the safe place i put them :roll:
Google knows all :wink:
Re: FB ute
Highly modified now Blacky !
Re: FB ute
I have a VN VP cruise control kit that my son got for me when he was working at a Holden spares place, it wants to use a body control module but I just not tech enough to work it out yet.
I'll have to really sit done and see if I can get my head around it, I assume that the body control module would need to have feed from the computer this is where I come unstuck :wtf: :wtf: :wtf:
Re: FB ute
Open circuit with a paper clip?
Re: FB ute
Cruise control done - need to put ute back together and road test - still got brakes to do yet
Control thingy ended up above the battery - a couple of nutserts to hold it up
Brainbox is next to glovebox
Re: FB ute
Heater is still not done , was waiting on a left side lever that a bloke from NSW sent me over - it got here yesterday and turns out was just 2 right side levers with the left one dodgied up Image
Seeing as he went to all the effort of sending it I figured I better use the bloody thing so I set to it with a grinder and a glue gun
How it is and how it needs to be -
Cut and shut -
Glued and ground ready for a quick squirt of cold gal
Rough enough- just need to get down to Autocables and pick up a section of push/pull cable to finish it off.
