Moderators: reidy , Blacky
Posts: 11648 Joined: Sat Dec 06, 2014 2:44 pm
Post
by Errol62 » Sun Jun 25, 2023 1:54 pm
Yes industrial welding earth as I recall Greg.
Can't see any thing on the lug blacky. 35 or 50 will work with that thanks fellas.
Made brackets from 2.4mm square tube.
Mocked up
Need to get some longer bolts for pedestals and manifold tomorrow.
Post
by Errol62 » Sun Jun 25, 2023 2:04 pm
0.12mm strands about 15,000 of the buggers. 12mm core diameter.
Post
by Errol62 » Sun Jun 25, 2023 4:09 pm
Just thought, need these on for balancing....
Posts: 5737 Joined: Mon Oct 08, 2007 2:00 pm
Post
by Harv » Sun Jun 25, 2023 4:19 pm
A set of red Unifilter socks cable-tied on, and yer done.
Posts: 14250 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Sun Jun 25, 2023 4:47 pm
Posts: 2705 Joined: Thu Mar 16, 2006 9:51 pm
Post
by EK283 » Sun Jun 25, 2023 5:45 pm
Clay,
That's damm big cable, because your measurements may be dodgy and because the cable looks like Tina Turners hair i'm going to predict the cable size as 4/0 gauge, 120mm.
Electrical wholesaler will have them with normally 8, 10 or 12mm bolt holes.
Su's look grouse !!
EK283 on Sun Jun 25, 2023 9:51 pm, edited 1 time in total.
Post
by Errol62 » Sun Jun 25, 2023 5:46 pm
I had to clearence things here
The throttle lever was fouling on the front two carbs. Also canted the brackets so pedestals sit upright to help clearence.
Post
by Harv » Sun Jun 25, 2023 6:27 pm
Yep, seems a little bigger than 4/0 cable. 2/0 for most stuff, 3/0 for long runs in voltage sensitive kit. The bigger size won’t hurt anything though.
The stubby coolers made me grin - Dave uses them to plug the ‘zorst on his Merlin hydroplane.
Post
by Errol62 » Sun Jun 25, 2023 9:23 pm
Thanks guys
Post
by Errol62 » Thu Jun 29, 2023 7:25 pm
With luck the switch snd pass through will arrive tomorrow so need to focus on getting some terminals.
Manifold came up nice in the tool pro blasting cabinet.
I will leave the ports alone as they measure same height as stock head, and 1mm narrower.
Post
by Errol62 » Thu Jun 29, 2023 7:30 pm
Some of the manifold studs are a bit close due to swept in runners.
Glen put me on to some 12 point nuts. Invoices are piling up. Three of everything……
gledge
Posts: 307 Joined: Thu May 28, 2015 11:01 pm
Post
by gledge » Thu Jun 29, 2023 8:30 pm
Get ya grinder out clay and linish the pads on the intake to be the same as the exhaust and a bit of clearance for the spacers
Post
by Errol62 » Thu Jun 29, 2023 9:22 pm
When I fit it to the actual head I will. Studs can be trimmed if necessary as well. Thanks Glen.
gledge
Post
by gledge » Thu Jun 29, 2023 9:26 pm
Way easier to set it up on another head off the car.. it flat surface and takes a bit of messing around.. how’s the battery relocation coming along?
Post
by Errol62 » Thu Jun 29, 2023 11:30 pm
Just want to get the actual exhaust manifold in the equation before I start linshing the bosses, in case it is different to the one I am mocking up with. I will do the clearencing though.
Hopefully get some terminals tomorrow and I will borrow your crimper over the weekend to make the cables up. Assuming the other bits arrive tomorrow.
