I see trees !!!!
Not much of the SA state has these, all crops and crap !!!
We just leave those bits for you mung bean munchers to travel through so it puts you off Greg… 8 ) 8 )
Thanks Patrick. Glen has a jig doesn’t he?
Oh, hang on. I get it now ha ha hah, oh dear….
Clay
How is water getting in the cab floor?
gledge
Post by gledge »
I will try and grab the jig out if ya want to use it Clay.. it’s over at my mates house at willunga in the back of my old truck?
Possible for a little water to get in mainly windscreen leaking in heavy rain and hosing off Stephen. It's not much. After I massage the tunnel I wil scrub the floor and marinate with thisImage
In the Shed wrote: Fri Aug 12, 2022 6:30 pm Clay
it's an FB holden same goes for EK if water gets on the outside it WILL get to the inside :wink:
Thanks Glen. Prolly won't get to it for a while so leap out the gate yet mate.
Finally got the invoice from Roger. Shift rods are at the platers then it can be dispatched. He charged me his old price because it took so long apparently. $1100 which seems pretty good since rares kits are $500 and then the shift conversion, rods etc. on top.
I haven’t bothered putting the floor mat back in since drying out after the Stansbury trip, still I won’t go hoiking the donk quite yet, just in case…….
Took a 35 minute phone call, but that included a lecture on lubrication and installation.
Mick wrote: Fri Aug 12, 2022 8:24 pm
Yes Mick. If you drive in the rain be prepared to pull out the flooring and dry things out, which is why I left the floor un-insulated, and the rear tray removable. :thumbsup:
Ixperimenting with tachometer positioning. I lashed out at Willunga swap on a $10 Sunpro. It is the Super tach II model, not mucking around here.Image
Knee clearence seems ok and can see with shifter in top but have to look down a bit. Not as bad as a HK GTS I suppose. It won't mount to column higher up with the column shift. On r adjacent the speaker grille would be an option less subtle although I mount the phone there currently.
I wonder if there is a tachometer app for the phone..... thinks
you wont be able to see the needle most of the time from that shot. :ninja22: :ninja22:
Nah. Got it turned around so I can see from 0 to 6k. Won't be going past that.
A vote for the speaker grille.
