1963 EJ Clutch questiion
- State: SA
Re: 1963 EJ Clutch questiion
Here is the link I omitted to include
https://www.powerbrakes.com.au/
Thanks for the link, will give them a call.
The slave cylinder with the offset bolt holes is for 179 EH, all HD, HR, and HK with crashbox.
EJ and 149 EH takes your style of slave cylinder with the symmetric flange.
Internally they take the same components; but the bellhpousing was redesigned for the 179, necessitating the change to the slave cylinder.
You'd be best off getting your existing slave cylinder stainless-steel sleeved.
Burt bros in Fairfield Sydney NSW will resleeve it or B & R brakes in Castle Hill Sydney NSW will also do the same.
Thanks for the replies and info, much appreciated.
I contacted Power Brakes and they can do it for A$130 pp and $9 for the piston.
I am going to send it away next week.
Thanks again, been doing my head in trying to order one!
B
B
Did a bit more looking tonight, and re-read EJVince's post, and noticed his gearbox had the spring the other way around as per the below pic from his thread.
Looking at EK283's pic on the first page, that one is the other way around that snaps easily around after moving just a few mm.
I beleive EJVinvce's is actually the correct way around, as when I install it this way, I can move the level 10mm and the spring is held in place. It also makes sense the way the clips on the lever are facing, as the mouse trap part of the spring is actually moving in that direction.
Weird thing is my original pics had the same way around as the pics EK283 posted. Maybe its just a mstake people make?
It is a shame the EJ EH forum has disappeared again. Would have been a good source for this, EJs are pretty unique in their factory gearboxes aren’t they?
'Unique' is certainly one word for them, not sure its the word I would use though, mines a bit more explicit.
Annoying thing is the 2 manuals I have cover so many things, but both don't have a bloody picture of the spring installed.
My gut tells me to go with the spring coils facing the housing, so I am going to install it that way
Most 149 EHs had the later 179 box & slave. It's only those 149s prior to engine no. 81520, which had the EJ setup.ardiesse wrote: Thu Apr 23, 2026 11:05 am The slave cylinder with the offset bolt holes is for 179 EH, all HD, HR, and HK with crashbox.
Dr Terry
Well done spotting the assist spring the wrong way around.
Dr Terry: . . . stand corrected. I'm basing my experience on the one 149 EH I had, which was engine number H3529.* Now that you mention it, a friend had an Aug '64 149, and I noticed nothing out of the ordinary with its gearbox, so it must have been the same style as our family HR.
* and I had no end of trouble getting rocker cover gaskets to fit. Its rocker cover had no cutouts to take the "tangs" in the gasket. But that's off-topic.
Again my reply vanishes into the ether . . .
one more thing - I notice that your bellhousing has red overspray inside where the starter motor goes. Red, not grey. Could you possibly have an early EH 149 bellhousing? ETA: Belay that. In the photo with the new slave cylinder, it's definitely an EJ bellhousing.
(Control-A, Control-Insert for safety)
Heya,
Does anyone have any recommendations for oil for these 3 speed gearboxes?
I see it takes a SAE 90 straight run mineral oil, but looking on the net there are alot of different suggestions.
Penrith Transoil SAE 90 seems like a good one, just not sure if anything else that may be more readily available?
Also, what is the capacity? Looks to be around 1L?
Yeah. It must have been quite early. Only very early EHs got the rocker cover with no cutouts.ardiesse wrote: Fri Apr 24, 2026 12:21 pm * and I had no end of trouble getting rocker cover gaskets to fit. Its rocker cover had no cutouts to take the "tangs" in the gasket. But that's off-topic.
Dr Terry
- State: SA
Hi
For oil I have just used Castrol manual transmission oil which from memory is around 70/90w. Seems to do the job ok.
For quantity doesn’t the workshop manual specify quantity or fill to within xx inches of fill point? Mind you your gearbox is unique.
Is your gearbox back in the and ready to roll? Was wondering how you got on.
I use 80W-90 in gearboxes and diffs. The capacity is a litre, give or take. The correct level is within a quarter-inch of running out the filler plug hole.
