what you buy when FB/EKs become to expensive
Oldnblue
Re: what you buy when FB/EKs become to expensive
Post by Oldnblue »
Keen to see lowered photos. Blocks and simple cut of the springs Mick?
cut springs all round :)
Sputzwagon
Post by Sputzwagon »
...good thing J is'nt reading this or he'd tell you to toatally remove the springs altogther!!! :shock: :lol: :lol: :lol:
Scotty.
Woofto Car Club Member No 2
the back ones fall out when you jack it up now :oops: :lol:
Oldnblue
Post by Oldnblue »
lets see...!!
Oldnblue
Post by Oldnblue »
Forgotten that they weren't running leaf springs in back...been driving old Holdens too long. doh!
here's the lowered pics could come down a little more in the rear but as i said the springs fall out allready when jacked up
Sputzwagon
You can always run a piece of chain from the body to the diff somewhere to stop it from spitting out the springs when at full drop, Mick. :thumbsup:
I did this to a lowered arsed bike id built in the 80's...it worked well. :wink:
Scotty.
Sputzwagon wrote:You can always run a piece of chain from the body to the diff somewhere to stop it from spitting out the springs when at full drop, Mick. :thumbsup:
Scotty.
:thumbsup: that was my thought, from memory years ago with another i had i got shorter shocks, it's only real an issue if it goes on a hoist
gotta use 2 jacks to jack it up one under the diff to get the wheel off the ground and another under the body to raise it for clearance and just watch that the spring still has weight on it, but i need 2 for the front aswell one to get it up a little to get the other under :lol: gotta love low cars :lol: :lol:
Harko
Post by Harko »
What about a larger front wheel to lift it up to a level sill.
That way the arse won't have to go down any more and the front should have a lower tucked look mick.
There's plenty of room under them guards for a skinny 7" front runner huh
wot179
Post by wot179 »
Waddya torkin about Harko???
Make it HIGHER???
Just cut another half off the back ones,Mick. :lol:
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Harko
Post by Harko »
I just gave myself an uppercut and slapped myself
yeah allready 15" front wheels and i allready have bought new front tyres the same as fitted plus i'm not a huge fan of real tall tyres and as has been mentioned lift something up :shock: :shock: :shock: where is the fainting emoticon :ewink: :lol: as i speak the back of the car is jacked up and a bit more will be coming off the rear springs when things cool down a little outside :thumbsup:
finally painted the rear section and put 15" rear wheels on so i could fit the rear caps, after sorting out the running issues ............ kinda :roll: :lol: ya gotta love mystery engines thought it would be a stocker haveing small exhaust and cast iron 2 barrell manifold but did sound cammy (put that down to running bad) first clue was when heads were off 307 but bored out to 4"+40 bit excessive just for a rebuild :wtf: tryed ajusting rockers as you normally would ajust hydraulic lifters not happy, did this numerous times till a mate had a go then did comp test seen nothing on some cylinders so backed rockers off on those cylinders jumped straight up, so set rockers as you would with solid lifters runs perfect :) but real lumpy put noisyer exhaust sounds even better :twisted: and have to run the car on premium it just won't run on anything else, BUT there is a down side to all this it needs atleast a stall converter it won't idle in gear and is a dog under about 2500rpm a manifold and bigger carby definately wouldn't go astray either :ewink: but these will be the new owners worry not mine
:thumbsup: nice one Mick. Sounds like a great mystery engine!
