Grecian White/Apache Red 225
Craig Allardyce
Post by Craig Allardyce »
Thanks Stewart. I'm looking forward to the Nats. I've been spending the last couple of days re-jetting the carby. Its quite a simple process with the only drama I have is with venturi sizing and main jets/emulsion tubes. I'm setting up a air fuel ratio meter so I can do some testing (wish I had a dyno) and get that sorted. I think I've raved enough about these carbies but they are really good for configuring to a particular engine. Yesterday I even changed out the main jets with the engine running!!!
How's old timer going?
8) Maybe I can scam cruise around the block in the Apache whilst we are at the Nats...?
Old Timer is going strong and enjoying taking her out when I can. :thumbsup:
Craig Allardyce
[quote="parisian62"]8) Maybe I can scam cruise around the block in the Apache whilst we are at the Nats...?
Sure thing. I'm sure we can arrange something. :wink:
Craig Allardyce
Thought I'd post some more up to date pictures of my engine after finishing of tube work for fuel, vacuum, and coolant lines. I'll try put up another of the drivers side of the engine.
Looking good Craig! :thumbsup: :thumbsup:
8) Top stuff.
Craig Allardyce
Thanks guys.
very nice, looked a treat at the nats 8) 8) 8)
Craig Allardyce
Thanks Blacky.
Yours took my fancy a bit and a lot of others at the Nats looked fantastic. Now I'm keen to get my ute done......although I have to finish the FB and the boat and buy a house and move and................................... :roll:
There's never enough hours in day when your home.
Anyway I've sent more trim samples off to the States. My recent dilemma is I've now discovered that somewhere in time they have had a production change with the widths of the rear seat back (upper section). I have two different bolster sets from different cars and they are different in width and there's no way it could be made up in assembly or the fabric could be stretched that far. The frames must have been slightly narrower.
Anyone else come across this??
stinky
Post by stinky »
Vinyl, new vinyl especially, can stretch a lot. Considering it is across the width of the seat you can expect to stretch the vinyl quite a bit, 20mm to 40mm in the extreme.
Craig Allardyce
stinky wrote:Vinyl, new vinyl especially, can stretch a lot. Considering it is across the width of the seat you can expect to stretch the vinyl quite a bit, 20mm to 40mm in the extreme.
Thanks Stinky yes I agree new vinyl can stretch a lot. My comparison is of two trim sets that are as old as the car i.e. they've had all the stretching that they will ever get and are now quite aged and stiff. With that in mind the measured difference is quite a lot between the two.
I think when I get these seats redone with my new trim I'll do some measuring when they are stripped and compare to another old one I have. I'm still dubious and wonder if they made some adjustment in manufacture to allow easier fitment of the rear seat to prevent damage to the headlining. I know from experience in the past that some are real tight to get in and can grab on the headlining side sections.
Craig Allardyce
Its been a long time between road trips but we've managed to finally get away for a day now that we have done our house move.
We spent the day cruising up to Dargo and the surrounding areas with a stop at the pub...of course. Spot of the day was by the Wonnangatta River just out of Dargo.
We've also started to tackle these new fangled Gopro camera things and now have to work out to edit all the footage.......the good wife might sort that....I hope!
bootlegger
Post by bootlegger »
Enjoy that car. My new years resolution will be to finish my fb ute.
Craig Allardyce
Hi Dave,
yes I have few new years resolutions but as you know.................
Next year I'm going to make a start on my EK ute but I have to get a plan going with the boat first. Looking forward to see your ute on the go.
fingers
Post by fingers »
Looking good Graig .......still enjoying what Gippsland has to offer .....................Fingers :thumbsup:
