Patrick_R
Post by Patrick_R »
Mate,
How good does she look out in the sun.
So close now mate.
Yep
Bit of shopping done today at jcar and aveska. Ian at Aveska is a helpful and knowledgeable boy who has been around and knows his stuff regarding old holdens in particular and rubers and seals in general. Got the 2.4 metre length of weather stripping cut in four and sent over from briz for $70. Now have to fit the clips. Also the q.v. rear seals for $7 each. They are a bit longer to fit Bedford trucks. Q.v.s were gettin a refurb but waiting for mate to bring back the contact so on to headlights.Image
Reinstalling the Bosch headlights that came in the car with help from Ardiesse with done donated parts. Old wiring rubber hose was cactus so got 5/16" id trans hose from supzcheap. Nitto tape and shrink wrap from Jcar blended on to the remains of the original grommets. Don't think you can get hoses for the Bosch lights and most FB EK I've come across have the Lucas lights. Just a silly detail about this car makes it s bit different. May have been a Fishermans Bend thing. Reused original gaskets as they were good and once again I'm not sure you can get replacement for Bosch.ImageImageImageImage
Now that has been a journey. It s been well over two years since Rob sent me these lights.Image
Neat Clay,
I like the Bosch headlight glass, as you say a little different. Good attention to detail with the slot head screws retaining the headlight trims as per original.
Very Interesting on the lights - never new there was a different brand used - The Better auto rubbers should fit both by the looks as the hole in the bucket looks about the same but they are little more than a sheath and quite thin so as long as water can't get in the back of the bucket they do the same job.
Errol62 wrote: Thu Oct 29, 2020 6:21 pm Reinstalling the Bosch headlights that came in the car with help from Ardiesse with done donated parts. Old wiring rubber hose was cactus so got 5/16" id trans hose from supzcheap. Nitto tape and shrink wrap from Jcar blended on to the remains of the original grommets. Don't think you can get hoses for the Bosch lights and most FB EK I've come across have the Lucas lights. Just a silly detail about this car makes it s bit different. May have been a Fishermans Bend thing. Reused original gaskets as they were good and once again I'm not sure you can get replacement for Bosch.ImageImageImageImage
Nah I've got a Lucas rubber and the hole in the bucket is bigger. My solution works and will soon be encased in even more cavity wax.
Closer and Closer Clay !!
Putting all the bling back on is exciting, Doing the door windows and rubbers is fiddly but you only have 2 to do !!!
Cheers Greg.
What an afternoon. Called in at Lonsdale Paints for more cavity wax and wax and grease remover. Then Rubber Seals Australia and got plain black Bailey channel @ $25 / metre. Rigid channel came at a good price $25 per door. El Presidente Roger put me on to these guys (RSA) and Aveska as well.
Raff had a parcel from the letter box for me which was random crash box bits from kev on the FC forum. I thought this was it as had received a noti earlier about parcel but then got a message to pick up at LPO. I thought this must be the old master cylinder I bought. Ten to closing Friday so race down and grab it. Gee it's well packaged. Bit heavy be cast iron. Express post??!ImageImageImageImage
Holy shit I can't believe it. Celebratory beer in order. Wiring loom has turned up with documentation specifying everything I axed forImage
Far out I'm pinching myself. Image
62ekute
State: ACT
Post by 62ekute »
Nice - fresh flexible wires ... and it looks like the inline fuse-holder for the wipers is plastic - I feel much more comfortable with that than the old metal ones with plastic sleeves around the fuse
They are bloody good buying at $600 :thumbsup: 8)
Father Christmas has come early....... whoo hooo!
Always wondered what a wiring harness looked like when it still had all the magic smoke in it. Looks very neat.
