Steve & Josh's EK wagon build
Re: Steve & Josh's EK wagon build
Hey Stan,
Go back to the start of this thread and read it mate. Much will be revealed to you.
Oh, and welcome to the forum mate!
Clay
Welcome Stan, you can send a private message to the original poster by either clicking on their name and selecting "send a PM" or clicking on the "private messages" tab in the top right of the screen
Had a look through the build and enjoyed it. Coming from a current steering column engineering journey, it seems that the steering column doesn't look compliant with ADRs. Looks like it has the original u-bolt setup on the steering wheel end and no breakaways. It would not collapse properly in a crash if that is the case and would not pass engineering (in NSW anyway.) Maybe worth looking at😀
Brett
Yes Brett is correct.
I love this diagram, a picture tells a thousand words.
A good engineer wont pass it with the ubolt set up.
Nice car by the way.
Australian laws are weird - when we were in Wrongway Rogers shed discussing his EK sedan build he mentioned to the engineer he was thinking of using a VL column so it was collapsible the engineer asked him why do you want a collapsible column ? Apparently not a requirement in SA :crazy:
Not required for a stock 202 in SA. Different story for V6/8.
Blacky wrote: Fri Apr 18, 2025 10:08 am Australian laws are weird - when we were in Wrongway Rogers shed discussing his EK sedan build he mentioned to the engineer he was thinking of using a VL column so it was collapsible the engineer asked him why do you want a collapsible column ? Apparently not a requirement in SA :crazy:
in NSW they just move the goal posts as it suits them, never used to need dual circuit or collapsible column for any of the holden straight 6s and could rego 138 red or 149 with no engineering now you need engineers for all and same requirements across the board no matter what size, though i have found an engineer that apparently isn't quite so hard on 138s and 149s and some times can still sneak a 138 or 149 through just with a blue slip some times bigger as due to their age and rego people being younger and younger as long as it doesn't look like a late model engine with fuel injection and such they can also sneak through
