Family Affair Ek Ute
Sneezy1211
Re: Family Affair Ek Ute
Post by Sneezy1211 »
Harv wrote:Yep - control arm spacers, as per the below (this image from the FE/FC manual):
I haven't got the HR manual here, but my notes say that the upper tool (3A12) is different to the lower tool (3A11). I've got both tools at home to measure or loan you, but am a fortnight or so before I get home.
Hey Harv
That's the one I'm talking about mate cheers , some measurements would be great if possible and I'll see if I can chase up a hr manual and check if it's the same tools
Sent from my SM-A546E using Tapatalk
Try these dimensions.
Sneezy1211
Brett027 wrote:Try these dimensions.
Awesome thanks Brett! Do you know if that is the size for lower and upper ?
Lower 40mm, upper 20mm from memory.
I don't bother with those, just eye them up and get them even front and rear :thumbsup:
Ditto
The spacers stop the arms bending in when you torque the nuts up to spec. As an old friend on this forum once said so aptly, 'do it once, do it right'.
Sneezy1211
So we got it home from paint and panel on the weekend now the big job begins.
Very exciting. Looks fantastic Col.
Beautiful.
Sweet as a sugar sandwich mate 8) :thumbsup: now the fun part - putting everything on once and some things twice :lol: I would start with pedal box then wiring harness and wipers - get the crap under the dash done first
Looks great 👍
Sneezy1211
Blacky wrote:Sweet as a sugar sandwich mate 8) Image now the fun part - putting everything on once and some things twice Image I would start with pedal box then wiring harness and wipers - get the crap under the dash done first
Hey Blacky
That was next on the agenda sit down and write down a order of things to do . Wiring is definitely number one . Putting the pedal box in and working around it was in my head also. Still need to work out where we will mount the fuse panel and the steering column is still a few a few weeks away from being ready. Will be able to run a lot of wiring and get s fair bit done. I will be plenty of thought and planning into that side of it.
Love it Sneezy it looks fantastic, suggestion :eh: make sure you tap over your paint etc when you are assembling, putting engine in and windows etc :problem: don't ask how I know this is a good idea. :crazy:
Low adhesion tape though. I always worry about pulling fresh paint off with tape.
