Mustang Fuel tank Sender Problems
funkyscooter
Re: Mustang Fuel tank Sender Problems
Post by funkyscooter »
ardiesse wrote: Wed Jul 09, 2025 12:32 pm
Using a resistor in parallel will affect the linearity of the resistance/fuel level relation.
Hey Rob - I didn't find to be an issue when tested previously but I will have another check. Rewinding is an option I hadn't really considered.
Blacky wrote: Wed Jul 09, 2025 3:42 pm Do you have the room to extend the float arm to limit travel so it only goes from zero to thirty ?
Geez Blacky - you could have given me that bit of brilliant advice before I stuffed around with all this electronics shinanigans :lol:.
Looks like its out with the multimeter and the sender again to see if that's the go.
Thanks
Scott
