Hidden wiper motor
Re: Hidden wiper motor
bump for Gazza
- WesternWagon
- State: WA
Cheers mate
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
Be aware that you can use use a Preslite VN wiper motor if you want 2 speeds. It bolts straight to your mounting plate but you must use the long drive arm see picture. You can't use early Holden wiper switches as they are earthed switched as the VN Motor is power switched. The VN motor allows you to use the Holden column switch and add intermittent delay. You can use the switch 75228-03BX shown earlier in this thread for dash switch for the VN Motor.
- EK VN Wiper Casting Diff.jpg (594.09 KiB) Viewed 6792 times
More good info. BA fraud also and they are trico brand.
That’s the motor I used in the conversion above matemr48215 wrote:Be aware that you can use use a Preslite VN wiper motor if you want 2 speeds. It bolts straight to your mounting plate but you must use the long drive arm see picture. You can't use early Holden wiper switches as they are earthed switched as the VN Motor is power switched. The VN motor allows you to use the Holden column switch and add intermittent delay. You can use the switch 75228-03BX shown earlier in this thread for dash switch for the VN Motor.
