Did you manage to fit one of the XW / XY tanks ?ek wazza wrote: Sat Jul 25, 2020 5:41 pm Bought a couple of early &*#@ fuel tanks to play around with I think XW and XY. Anyone have any pics of the conversion?????
FUEL TANK REPLACEMENT
Re: FUEL TANK REPLACEMENT
In the process at the moment. Had engineer check out my build yesterday and he had no problems with progress. Fitting from the top not underneath is the way to go. XR/XT/XW/XY seems to fit the best but I also tried the XA/XB tank which is not as square.
- XA/XB
- 20201217_123426.jpg (4.13 MiB) Viewed 2101 times
- XA/XB
- 20201217_123433.jpg (4.08 MiB) Viewed 2101 times
- XR/XT/XW/XY
- 20201105_143556.jpg (4.2 MiB) Viewed 2101 times
- XR/XT/XW/XY
- 20201217_140350.jpg (4.7 MiB) Viewed 2101 times
Building an EK Special Sedan 304 T700, Rodtech F/end with disc's front & rear, and driving an EK Special Sedan Grey with Trimatic and the rest stock
Hey Wazza looks good and I have seen a couple of other builds on here or the FE/FC forum using them the only thing I don't like about them is the height into the boot but I suppose they do give you the option for the spare wheel.
How are you intending to finish off the boot floor? I think one of the other builds used ply to make the false floor.
Not really sure yet how I’m going to finish off most probably with ply or custom wood. Sitting the tank on the rail flanges gets it lower than what I have seen. What you lose in the height of it which isn’t much, you gain more room by not having the spare sitting vertically plus an increased fuel capacity
How's it look from underneath ?ek wazza wrote: Mon Feb 01, 2021 11:36 pm Not really sure yet how I’m going to finish off most probably with ply or custom wood. Sitting the tank on the rail flanges gets it lower than what I have seen. What you lose in the height of it which isn’t much, you gain more room by not having the spare sitting vertically plus an increased fuel capacity
I’ll show some pics soon. Just working on different areas at the moment
Cheers.ek wazza wrote: Mon Feb 08, 2021 10:12 pm I’ll show some pics soon. Just working on different areas at the moment
Would a metal tank ( like a mustang) require straps Blacky?
Blacky thanks for sharing the pics!.....The Commodore tank appears to hang lower than the quarter panel ?
Cliff Regan
- State: WA
Guys,
Done the same as Blacky with my FB Sedan (VS Commodore tank), the only difference was I fitted a 3mm plate under the boot area to have a clean area for the tank to fit up against. this also nicely covers the old tank and spare wheel areas.
Perth Hills lowrideroz_ek wrote: Thu Feb 11, 2021 12:49 pmBlacky thanks for sharing the pics!.....The Commodore tank appears to hang lower than the quarter panel ?
Youtube
Mustang tanks are mounted in a similar way to the stock tank so no straps required.Brett027 wrote: Thu Feb 11, 2021 12:35 pm Would a metal tank ( like a mustang) require straps Blacky?
Maybe it does - I cant remember ....oz_ek wrote: Thu Feb 11, 2021 12:49 pm Blacky thanks for sharing the pics!.....The Commodore tank appears to hang lower than the quarter panel ?
