Carpet Install
Re: Carpet Install
I would think option 2 ? the theory behind doing the doors is to stop the skin from "drumming" I thought , you don't need to completely cover the inside of the skin to achieve this, modern cars have a large section o the skin covered with deadener but not all of it .
Re: Carpet Install
Modern cars also have relatively waterproof weatherstrip compared to FB EK. Suppose if you put plenty of rust prevention on first i would consider it.
camstuart52
State: TAS
Re: Carpet Install
Post by camstuart52 »
steved57 wrote:Hemco mate. They've got everything you'll need and more.
In regards to Hemco retractable belts. I have contacted them and sent me some info regarding the reel size and position, my seats arent in though so i cant check if they will fit. Im hoping someone can assist and say yes?
Obviously back ones are simple enough.
TIA
Cam
Re: Carpet Install
I've got Hemco retractable reels in the front of my EK wagon. Fitted OK with the factory bench seat.
camstuart52
State: TAS
Re: Carpet Install
Sweet thanks Harvs
Did you have to make an L bracket to fit them?
Re: Carpet Install
No, Hemco sell the L-brackets.
WayneXG95
Re: Carpet Install
Post by WayneXG95 »
If your putting carpet in (which I'm against due to rusting) I'd paint at least 3 coats of POR15 on the floor.
I know rubber mats help rusting as well, but the smell of wet carpet. :shock:
As was said previously FB and EK's leak.
Cheers :thumbsup:
camstuart52
State: TAS
Re: Carpet Install
I've got kill rust that will be applied
I'm assuming you don't like the idea of carpet and recommend the molded rubber?
WayneXG95
Re: Carpet Install
Post by WayneXG95 »
camstuart52 wrote:I've got kill rust that will be applied
Isn't kill rust for already rusted metal?
Your car you choice but personally I'd prefer the moulded rubber over carpet due to leaking but you can always put carpet mats in.
:D
