cheers
Nathan
You can, though the bolt-on twin pulley will sit out much further forward than the original grey harmonic single groove. This means that whichever of the twin grooves you choose to use will not line up with the water pump and gen... you would need to move both waterpump and gen forward too.Blacky wrote:You could run one of those pulleys Harv , and run one belt to the water pump and alt/gen as per stock and use the other for the aircon compressor ???
