FB wagon
Re: FB wagon
Looks the goods Trev!! Great idea with the lowering the rear end...I didn't think of that at all
.... bump stops are over rated and are made long so they can be trimmed to suit
Re: FB wagon
Trev wrote:It ended up being noisy timing gears, wasn't expecting that kind of noise from them, but they will quieten down.Devilrod wrote:What a pain in the ass Trev!! Good luck.
Glad I got it checked out for my own piece of mind
Woo Hoo!!!! Doing my rear suspension Saturday if all goes to plan
Re: FB wagon
Raising the suspensionDevilrod wrote: Woo Hoo!!!! Doing my rear suspension Saturday if all goes to plan
- State: NSW
- Contact:
Re: FB wagon
glad to hear you got the engine sorted...doesn't sound like you had to open your wallet at all...!
Re: FB wagon
Trev wrote: , It just doesn't feel rite
I know, but the girls think its great fun bouncing around everywhere. My aim is to get some clearance and hopefully not lift it too much.
Re: FB wagon
DR what diff housing do you have ? if it's EJ,EH,HD,HR with the round peaked bumpstops on the housing instead of the factory ones that bolt to the body, i do the same with them as i do with the fronts cut them down then grind them back to a peak
Re: FB wagon
Picked it up today, drove it home (87 km) and it didn't miss a beat, the diff is very noisy but the engine ran greatparisian62 wrote:glad to hear you got the engine sorted...doesn't sound like you had to open your wallet at all...!
Re: FB wagon
did you put oil in the diff ? i did that once cept i never put the centre in just after i put the car togeather i never checked how much oil was in the diff
and it wasn't enough
Re: FB wagon
EJ, but silly me welded on the EK brackets to use the standard EK bumpstops. I've got an extra leaf for each side thanks to Trev so I'll see how we go. Its dropped over an inch since its been on the road....ratbox wrote:DR what diff housing do you have ? if it's EJ,EH,HD,HR with the round peaked bumpstops on the housing instead of the factory ones that bolt to the body, i do the same with them as i do with the fronts cut them down then grind them back to a peak
Re: FB wagon
Yep she was oiled up, replaced the wheel bearings last night and she's still singing like a bird, so I'll replace the center next, Trevratbox wrote:did you put oil in the diff ? i did that once cept i never put the centre in just after i put the car togeather i never checked how much oil was in the diffand it wasn't enough
- Sputzwagon
Re: FB wagon
What ratio diff center are you running in the wagon, Trev?Trev wrote:Yep she was oiled up, replaced the wheel bearings last night and she's still singing like a bird, so I'll replace the center next, Trevratbox wrote:did you put oil in the diff ? i did that once cept i never put the centre in just after i put the car togeather i never checked how much oil was in the diffand it wasn't enough
Scotty.
Woofto Car Club Member No 2
Re: FB wagon
3.36 .Sputzwagon wrote:What ratio diff center are you running in the wagon, Trev?Trev wrote:Yep she was oiled up, replaced the wheel bearings last night and she's still singing like a bird, so I'll replace the center next, Trevratbox wrote:did you put oil in the diff ? i did that once cept i never put the centre in just after i put the car togeather i never checked how much oil was in the diffand it wasn't enough
Scotty.
Got it regoed today
Re: FB wagon
Amen
Re: FB wagon
Great stuff Trev, another classic on the road, well done
Re: FB wagon
kool trev, shame i'm not going to the nats i'de be very interested in going for a drive in it to see what it goes like mild grey and trimatic
