red motor bolt torque settings.
matches
Post by matches »
i have a red 186 out of a ht and i need to know the conrod bolt, crankshaft and rocker torque specifications. can anyone help? i haven't got a workshop manual yet to find out but i'm impatient. :x
FB MAD
Post by FB MAD »
Are you using adjustable rockers or non adjustable?
matches
Post by matches »
non adjustable (standard)
FB MAD
Post by FB MAD »
I'll have to give you the info tomorrow arvo as the shop manual is in the shed and I'm off to the fart sack now for some Zzzzzzzzzzzzzzzzzzzzzzz.
matches
Post by matches »
no worries, thanks heap.......... yeah my boss would kill me if i went out playing with engines at this time of night, its bad enough me being on here finding things out about the car when i could be sitting watching a movie with her. my bad :wink:
luke
FB MAD
Post by FB MAD »
From Gregorys workshop manual HQ-HZ.
Conrod nuts:- 26 ft/lb
Crankshaft main bolts:- 70 ft/lb
Rocker arm pivot bolts ( non adjustable rockers ) 28 ft/lb
Cyl head bolts:-
1st stage:- ( start at centre of head and move outwards ) 30 ft/lb
2nd stage:- 75 ft/lb
Thought I'd throw in head bolt torque settings as well :roll:
If your torque wrench doesn't show ft/lbs the conversion is :-
1x ft/lb = 4.45 NM ( Newton Metres) and 1 x NM = 0.225 lb/ft.
matches
Post by matches »
thanks so much for looking that up for me, much appreciated. now i can get my 186 finished :D :D :D luke & kimmy
