Disassembling Leaf Springs
EKSPCL
Post by EKSPCL »
Is it possible to disassemble and reassemble a leaf spring yourself?
The reason is so that I can paint each individual spring, rather than just paint over the outside.
I'm thinking enamel would be the best type of paint to do this as it has a bit more 'flex' than an acrylic paint.
Has anyone tackled this before?
My 6yr old daughter said
Craig
Post by Craig »
Better dead than red
EK, the VN of the 60s
EKSPCL
Post by EKSPCL »
Sounds good :!:
Thanks Craig
Sammy
Post by Sammy »
don't forget to get new plates that go between each leaf!
Regards,
Sammy.
http://www.oldholdens.com
Post by mrs ratbox »
i've never had a drama, once you have the spring seperated from everything just undo the centre pin pull the straps apart and they'll be all apart
EKSPCL
Post by EKSPCL »
Any idea where I would get the 'plastic bits' for between the leaves?
Any springworks should be able to supply them.
Sammy
Post by Sammy »
a few yrs ago dad got them from holden, but i doubt they'd have them anymore as they don't seem to be able to get even 1994 model commodore stuff .... gone are the days!
Regards,
Sammy.
