front swaybar
yeprat1
front swaybar
Post by yeprat1 »
hi guys just wondering are there any benefits of adding a sway bar for handling purposes on a lowered fb
SHIT YEAH !!!!
(AUST)Mod
Post by (AUST)Mod »
Don't forget a rear bar too!
yeprat1
Post by yeprat1 »
i forgot to ask if it is made to fit a standard fb,ek will it fit with a red motor
Highly recomended
(AUST)Mod
Post by (AUST)Mod »
Yep it will fit with a red :)
I can only speak for those that don't have one, and mine drives fine, I do have pedders heavy duty lowered suspension on the front, mine is steady as a steady thing (it's the best I could come up with, too drunk :roll: ), Trev 8)
ben
Post by ben »
Can't think of any reason not to run a front sway bar. I don't run them on the 4wd if doing some serious rock hoping, as it gives you more indendent
wheel traction. Its like a boat on the road though. Maybe when as low as trevs, the low centre of gravity would not produce a lot of body roll to notice a sway bars effect. I would not bother fitting a rear sway bar if your car is lowed, unless you like to step the rear out round corners :twisted:
Post by mrs ratbox »
van had no sway bar at all but very stiff and low springs
stable at 190kmh by the tom tom :)
ipg
Post by ipg »
whats the biggest rear sway for a ute?
and where do i buy one?
Brown Bear
Post by Brown Bear »
I have a rear sway bar that was bought second hand but was originally from K-Mac in Sydney. Came out of a ute and fitted the wagon OK so I guess they must be much the same.
Can't tell you off hand what its diameter is, but can say that it works well!
K-MAC SUSPENSION P/L
366 Princess Highway
ROCKDALE NSW 2216
Ph (02) 9556-1799
Fax 02 9556-1507
E: sales@k-mac.com.au
W: www.k-mac.com.au
On safari
(AUST)Mod
Post by (AUST)Mod »
I ordered a rear sway bar direct to my door from K Mac a few weeks ago. It arrived promptly and I have told classic olden to bung it on for me :) I found that with my lowwww springs and all, the rear wheels rubber on the inner guard.
