Red Rattler Revamp
Re: Red Rattler Revamp
FireKraka wrote: Mon Jul 28, 2025 12:10 pm Hi Blacky I thought that the Eaton M90 only pout out about 6 psi standard on the L67 (my Monaro) and the smallest pulley gets you to about 18 psi, 35 psi sounds like an awful amount of boost then :eh: :econfused:
Its reading 35 lb of boost even at idle mate - there is a problem with the gauge .......
:crazy: :wave:
Had Jeff Ramsay come to look at the FED and start thinking through how to extend the blower snout. He reminded me you CAN squeeze 35 pissies into a red…
https://m.youtube.com/watch?v=Lmpzg0GOXtA
Youtube
There’s hope yet for that boost gauge Blacky :mrgreen:
Here's hoping :lol: :lol: :lol: :lol: :lol: wheels up launches in the rattler would be fun :twisted: :twisted: :twisted:
WesternWagon
Post by WesternWagon »
Sweet
Member : Holden Car Club WA.
:ASRF Member
basic.green
Post by basic.green »
hi. any movement on the old girl.. watching with interest
building the dream Rick
new alternator has arrived, waiting on a new boost gauge sender unit which is due 18/08 then back into it.
WesternWagon
Blacky wrote:new alternator has arrived, waiting on a new boost gauge sender unit which is due 18/08 then back into it.
:ASRF Member
one step forwards , another step and a half sideways , a shuffle back again then a pirouette ..........
Mike came back today with the hope we would finish the tune in the shed ready for dyno time - but was still having trouble with the air and water temp apparently fighting each other when he was trying to load a program into it.
Turns out the diagram I wired it to was not quite correct , all the negatives are drawn as going directly to earth but some of them really need to go back to an earth input in the computer , namely the air, water and throttle position switch so its time to pull the wiring harness apart , locate the cables in question and rewire them to the computer not to earth .............
................. it's getting awfully close to all this crap coming off and a set of triple SU's that are hanging around in the shed being put to work...... :evil: :evil: :evil:
Little problems,
Keep going you’re so close it’s not worth turning back now.
I’m really keen to hear this rumble.
I'm with Greg - looking forward to hearing this one spin up.
Got the earth wires sorted by pulling it all apart - again ImageImageImage just waiting on the guru to tell me where they need to go
Well , Mike turned up at home today and we got back into it - as soon as we put power on the thing the fuse blew :esurprised: :evil: :evil: :evil: :evil: :evil: :evil:
After much wailing and gnashing of teeth it turned out it was an ID 10 T fault in the computer, the bloke wiring it had earthed the wrong end of one of the sensors..... :oops: :oops: :oops: :oops: :oops:
Sorted that out and the tune is now done as far as it can be done - off to the dyno next :D
Tomorrow I need to tidy up all the wiring that now looks like a dogs breakfast, chase down a slight coolant leak, put the front doors back on and take it for a squirt around the block a few times and see if I can lower the arse a couple of MM, if you know what I mean :twisted: :twisted: :twisted: :twisted: :lol: :lol:
Farking excellent mate!
Blacky wrote: Fri Nov 14, 2025 6:46 pm … and take it for a squirt around the block a few times…
https://m.youtube.com/watch?v=hrLqgmjNa ... 4Bo7VqN5tD
