That is a very short ratio diff. Any idea what the overdrive ratio is in the box you have? Sorry about all the questions. Just thinking about how many revs you’ll be doing at the speed limit. 25 inch tyre height and 0.9:1 overdrive would be around 4500rpm. You could go up to around 27.5” tyre with 0.8:1 overdrive and get 3600rpm at 100kmh.
Yeah sorry, that figure is for 100mph. Using the Tremec app Harv. Stock 6.4R13 tyre is 25.27”. 3.89:1 diff the old grey is going 3216 rpm at 62.15 mph. With the 3.7 and 10% overdrive it is more like 2800 rpm. Bit more than my ute with the 3.08:1 in top at 2500rpm. My bad.
Errol62 wrote:That is a very short ratio diff. Any idea what the overdrive ratio is in the box you have? Sorry about all the questions. Just thinking about how many revs you’ll be doing at the speed limit. 25 inch tyre height and 0.9:1 overdrive would be around 4500rpm. You could go up to around 27.5” tyre with 0.8:1 overdrive and get 3600rpm at 100kmh.
Hi Errol
Not sure mate box is a celica steel case 5 speed , will be running 15" wheels haven't got tyres as yet. The centre is a new true track and the gear set is new as well
The rear shock/lower spring mounting plates aren't on quite right. They need to be turned over so the shock absorber mounting stud is at the forward, inside corner and pointing forwards. And it would probably be a good idea to put a rear spring rubber and retainer between the rear spring and the shock mounting plate.
ardiesse wrote: Sun Oct 12, 2025 9:33 pm
They look OK to me... but then again, I know a bloke who once incorrectly tack welded a set of slapper bars with the mounting plates in that position...
orientation is important....png (1.12 MiB) Viewed 3037 times
Glad you caught my stuff-up before they were fully welded. Gracias, amigo.
