Spigot bush showed up, so got ready to put flexplate on. Bolts are ARP 200-2902,7/16 UNF with a fancy big head on them. Checked the instructions, and they get red loctite, a smear of lubricant under the head and leaned on to 85ftlb. The instructions also have a warning to make sure the flexplate holes are chamfered as the bolt head has a radius. Checked, and they are right. Time to bevel the holes, bevan.
Interesting that their torque converter bolts (shown in the wrong side of the flexplate below) are the same thread but smaller head and not chamfered.
- IMG_0205.jpeg (4.97 MiB) Viewed 7609 times
Checked the spigot bush on the flexplate, all good. Greased the spigot and went to fit into the crank, and no joy. Murphy struck again. Spigot is 1.093” according to my well-abused verniers. Crank bore is somewhere between 1.077” and 1.084”.
- IMG_0207.jpeg (5.5 MiB) Viewed 7609 times
I don’t trust my bore gauge, as it lost its little spring years ago. Will need to buy another one to measure the crank, then get the spigot machined to suit. Anyone interested in a small lathe job please?
The grand plan was flexplate then box back in using the lifting beam (can manhandle the box but the angle is awkward on your back). Needed to happen before the FED goes to Kennards Saturday, but don’t like my chances of getting the machining done that quick.
